Make a Custom iProperty equal to the Item in the Parts Only Bom
Message 1 of 13
I would like to be able to run an ilogic program from within an assembly that would update a custom iproperty named BomNo within all the parts to its corresponding Item listed in the assembly BOM.
Does anyone know the code that would do this?
Morgan
Replies (12)
Message 2 of 13
BrandonBG
Dim oAssemblyDocument As AssemblyDocument
oAssemblyDocument= ThisDoc.Document
Dim oAssemblyComponentDefinition As AssemblyComponentDefinition
oAssemblyComponentDefinition = oAssemblyDocument.ComponentDefinition
Dim oBOM As BOM
oBOM = oAssemblyComponentDefinition.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Parts Only") 'or structured
For Each oBOMRow As BOMRow In oBOMView.BOMRows
  Dim oComponentDefinition As ComponentDefinition
  oComponentDefinition = oBOMRow.ComponentDefinitions.Item(1)
  Dim oBOMItemNumber As String
  oBOMItemNumber = oBOMRow.ItemNumber() 'this is item number in the BOM
  MessageBox.Show(oBOMItemNumber, "BOM Number") 'just to show what's going on
  Dim oComponentDefinitionPropertySet As PropertySet
  oComponentDefinitionPropertySet = oComponentDefinition.Document.PropertySets.Item("Inventor User Defined Properties")
'custom property tab oComponentDefinitionPropertySet.Add(oBOMItemNumber, "BOM Number")
'creates the custom property and inputs the value Next
I think this accomplishes what you want, however, if the custom iProperty already exists, you'll get an error.
BrandonBG
Inventor2015
Message 3 of 13
Thank you.  This gets me part of the way.  This rule will be run more than once for a specific part and like you have pointed out you receive an error if you run it multiple times.
Message 4 of 13
Hi Brandon,
Any idea how to manipulate this code to get what I want?  This code copies the BOM Qty to a custom iProperty named AssemQty
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef= ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
iProperties.Value(oOccurrence.Name,"Custom", "AssemQty")= ThisBOM.CalculateQuantity("Model Data", iProperties.Value(oOccurrence.Name, "Project", "Part Number"))
Next
Morgan
Message 5 of 13
Could this code be adapted so the BOM item number be carried over to the view label?
Message 6 of 13
BrandonBG
Your code is working for me. I'm getting a new custom iProperty in each component.
What are you trying to get it to do?
BrandonBG
Message 7 of 13
BrandonBG
Yes, but I believe that the iLogic rule would have to be run in the drawing, not the assembly.
http://inventortrenches.blogspot.com/2012/01/set-your-drawing-view-labels-to-use.html
Scroll down to the UPDATE portion of his post.
BrandonBG
Message 8 of 13
Yes this code works to get the qty into a custom property.  I would like it to do the same but copy the BOM number to a custom property.
Morgan
Message 9 of 13
BrandonBG
I don't believe you can access the BOM Item Number through ThisBom.
See: http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-10A98DEE-0617-4D36-8FE5-B145929833E1
In the BOM window in the Assembly, there are three BOM tabs: Model, Structured, and Parts Only. It is my understanding that ThisBOM looks at the Model tab only. If you right-click on the column headers, then Runtime Column Customization, you'll see what data is available.
BrandonBG
Message 10 of 13
Hi Brandon,
Can the code be adjusted to use the 'Parts Only' bom?
Morgan
Message 11 of 13
BrandonBG
Yes . . .  but, the Item Number still isn't accessible.
Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences iProperties.Value(oOccurrence.Name,"Custom", "AssemQty")= ThisBOM.CalculateQuantity("Parts Only", iProperties.Value(oOccurrence.Name, "Project", "Part Number")) Next
I can't really explain why it's not there. ThisBOM doesn't have the same functionality that the BOM object has. See my earlier post.
BrandonBG
Message 12 of 13
eric.smyth
This is working for me. I do get an error when it gets to a part that cannot be changed. then stops the rule. I get around this by putting all those parts to the end of the list. is there a bit of code that will skip this or on error go to next?
Message 13 of 13
eric.smyth
for future users... this seems to work.
Dim oBOM As BOM
oBOMView = oBOM.BOMViews.Item("Structured") 'or structured Parts Only
  'MessageBox.Show(oBOMItemNumber, "BOM Number") 'just to show what's going on
  If oComponentDefinition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Then GoTo start
  	Try
				oComponentDefinitionPropertySet.Item("BOM Number").Value = oBOMItemNumber
				Catch ex As Exception
				customProp = oComponentDefinitionPropertySet.Add(oBOMItemNumber, "BOM Number")
			End Try
  'oComponentDefinitionPropertySet.Add(oBOMItemNumber, "BOM Number")
start:
Next
