Error on Browser Node Expansion
brianA32ZM
brianA32ZM
Hello, I am attempting to collapse all Model Browser Nodes with the exception of the Representations that will be expanded. I am looking for help as the code errors on "oNode.Expanded". Thanks in advance.
Dim oApp As Inventor.Application
oApp = ThisApplication
Dim oDoc As Document
oDoc = oApp.ActiveDocument
Dim oComDef As ComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oRepMan As RepresentationsManager
oRepMan = oCompDef.RepresentationsManager
Dim oDVReps As DesignViewRepresentations
oDVReps = oRepMan.DesignViewRepresentations
Dim oPanes As BrowserPanes
oPanes = oDoc.BrowserPanes
Dim oPane As BrowserPane
oPane = oPanes.Item("Model")
Dim oTopNodes As BrowserNode
oTopNode = oPane.TopNode
Dim oNodes As BrowserNodesEnumerator
oNodes = oTopNode.BrowserNodes
For Each oDVRep As DesignViewRepresentation In oDVReps
	oDVRep.Activate
	For Each  oNode In  oNodes
		If oNode.FullPath.Contains("Representations")
			Logger.Info(oNode.FullPath)
			Logger.Info(oNode.Expanded )
			oNode.Expanded = True
			oNode.BrowserNodes.Item(1).Expanded = True
		Else
			oNode.Expanded = False
		End If
	Next
Next
Error:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateSet(Object o, Type& objType, String name, Object[] args, String[] paramnames, Boolean OptimisticSet, CallType UseCallType)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase, CallType CallType)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments)
at ThisRule.Main() in rule: Rule1, in document XX-XXXX-T_Diverter_Template.iam:line 37
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
WCrihfield
Hi @brianA32ZM.  Just a quick thought...  I kind of doubt that this might actually help, but in your line of code for initializing the loop of BrowserNodes, try adding the variable's Type in there, so it is not seen as Object later within the loop.
For Each oNode As BrowserNode In oNodes
PS.  Another thing that might be a factor is the BrowserNode.Visible status.  I wander if the node is not visible, it may not like you accessing its Expanded property...just another thought that might be worth exploring.
Wesley Crihfield
(Not an Autodesk Employee)
brianA32ZM
Thank you. I might be a step closer, but not there yet.
Adding "As BrowserNode" had no effect, but I think you are no to something with the BrowsersNode Visibility.  I added a Try Catch statement and found out all the non-visible nodes failed. I then tried to make them visible (oNode.Visible = True) before expanding, however that did not change the status.
bradeneuropeArthur
try this out:
'MsgBox(oDVRep.Name)
If Not oRepMan.ActiveDesignViewRepresentation.Name = oDVRep.Name Then
	oDVRep.Activate
		'MsgBox (oNode.BrowserNodeDefinition.Label)
		Else
		End If
	Next
	End If
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Or try this:
	oDVRep.Activate
			Logger.Info(oNode.Expanded)
			'MsgBox(oNode.FullPath)
			Try
				Catch
			End Try
			Try
			Catch
		End Try
		Else
			Try
				Catch
			End Try
		End If
	Next
End If
Next
Arthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
brianA32ZM
bradeneuropeArthur thank you.
this line was not needed: If Not oRepMan.ActiveDesignViewRepresentation.Name = oDVRep.Name Then
The Try Catch statements helped me find the 3 nodes (Positional Representations, iMates, and End of Features) that were causing the error.  I should place the Try Catch statements back in, but the code below works.
	oDVRep.Activate
		If oNode.FullPath.Contains("Positional Representations") Or oNode.FullPath.Contains("iMates") Or oNode.FullPath.Contains("End of Features")
			'Do nothing
		ElseIf oNode.FullPath.Contains("Representations")
		Else
		End If
	Next
Next
