Error in Vb.net - copy of drawing
premysl.misun
Message 1 of 17
premysl.misun
I have part of program in VB.net which I use for copy of drawing and replace part in it by another. This work correctly before some weeks, but now I have error message in picture. I do not know why. With Inventor 2019 I uninstall some old versions of Inventor.
Thank you for your help.
Here it is program:
Module KopirovatVykres
    Dim _invApp As Inventor.Application
    Dim _started As Boolean = False
    Public Sub Kopirovat()
        Try
            _invApp = Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
        End Try
        Dim soubor As Inventor.DrawingDocument = _invApp.ActiveDocument
        If (soubor Is Nothing) Then
            MsgBox("Otevři nějaký výkres!")
        Else
            Dim path As String = System.IO.Path.GetDirectoryName(soubor.FullFileName)
            Dim path2 As String = System.IO.Path.GetFileName(soubor.FullFileName)
            Dim apprentice As New Inventor.ApprenticeServerComponent()
            Dim oDoc As Inventor.ApprenticeServerDocument = apprentice.Open(path & "\" & path2)
            Dim myFileSaveAs As FileSaveAs = apprentice.FileSaveAs  'Save the file to a new name
            Dim vykres_name As String
            vykres_name = InputBox("Zadej nové číslo výkresu")
            If vykres_name = "" Then
                MsgBox("Nezadán žádný název výkresu!")
            Else
                myFileSaveAs.AddFileToSave(oDoc, path & "\" & vykres_name & ".idw")  'Uloží otevřený soubor výkresu s názvem kopie před
                myFileSaveAs.ExecuteSaveCopyAs()
            soubor.Close()
            Dim oDoc2 As Document
            oDoc2 = _invApp.Documents.Open(path & "\" & vykres_name & ".idw")
            oDoc2.File.ReferencedFileDescriptors(1).ReplaceReference(path & "\" & vykres_name & ".ipt")
            Dim oDrawDoc As DrawingDocument = _invApp.ActiveDocument
            oDrawDoc.Update()
            oDrawDoc.Save()
    End Sub
End Module
Replies (16)
Message 2 of 17
bradeneuropeArthur
edit
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 17
bradeneuropeArthur
use this
and not this:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 17
premysl.misun
Still same error...
Message 5 of 17
bradeneuropeArthur
Do you have installed inventor and what version?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 17
bradeneuropeArthur
@premysl.misun
Take a look at the references for the project in VB.net.
like in the picture below.
Seems that the older version of inventor in missing now and need to be defined new with the new version of inventor.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 17
premysl.misun
I use Inventor Professional 2019. Before that I have 2017 and 2018. In old versions this program work.
I unistalled old versions (2017 and 2018). Maybe this is the problem.
In attachme are my references.
Message 8 of 17
premysl.misun
I can not find in COM  “Autodesk Inventor Object Library” 😕
Message 9 of 17
bradeneuropeArthur
then this is the issue.
make the reference and it will be solved….
C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Autodesk.Inventor.Interop\.............\Autodesk.Inventor.Interop.dll
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 17
premysl.misun
Unfortunately it not work :/.
I have version v4.0_23.1.0.0__d84147f8b4276564
Message 11 of 17
premysl.misun
List of my References in this project is in attachment
Message 12 of 17
premysl.misun
Any other solution?
Message 13 of 17
bradeneuropeArthur
What version of Visual Studio are you using?
Can you put this into a button definition and try what is happening?
    Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
        Dim oApprenticeDocument As Inventor.ApprenticeServerDocument = Nothing
        Try
            Dim oApprenticeServerComponent = New Inventor.ApprenticeServerComponent
            MsgBox(oApprenticeServerComponent.UserName)
            MsgBox(ex.Message)
        End Try
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 17
premysl.misun
I use Microsoft Visual Basic 2010 Express.
Your "button program" display error message. It is in attachment.
Message 15 of 17
bradeneuropeArthur
Do you have the correct frame work available.
seems that VS is a little to outdated?
.NET Framework Version 4.7 or later. Windows Updates enabled for installation.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 17
premysl.misun
.Net Framework 4.7 installed and problem is the same.
Can be this done by uninstall of old versions of Inventor (2017 and 2018)?
Message 17 of 17
bradeneuropeArthur
Read this!
https://forums.autodesk.com/t5/inventor-customization/problems-with-inventor-apprentice/td-p/5183865
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
