file save as .Step but After saving is shows .step.stepz & not open in another
file save as .Step but After saving is shows .step.stepz & not open in another software like creo/solidworks.
we try to another to open but no response of import file .
give me suggestion
how I can make .step file ??
pl. refer attached model
HermJan.Otterman
for a working script, look under Help, Programming help, in the samples.
there you can find this:
Save as STEP Translator Sample
Public Sub ExportToSTEP()
    ' Get the STEP translator Add-In.
    Dim oSTEPTranslator As TranslatorAddIn
    Set oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
    If oSTEPTranslator Is Nothing Then
        MsgBox "Could not access STEP translator."
        Exit Sub
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
        oContext.Type = kFileBrowseIOMechanism
        Dim oData As DataMedium
        Set oData = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = "C:\temptest.stp"
        Call oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
