Error in iLogic
Error in iLogic
johan.degreef
Advisor Advisor
Message 1 of 38
Error in iLogic
johan.degreef
All of the sudden this iLogic code gives an error. What i did: I did install Vsual studio to try to learn to code, and therefore I needed to install .net framework 4.8. That is what I have changed. I work on Inventor 2021. I guess it is since then then error pops up.
Imports System.IO
GetInput :
Dim Filename As String = "C:\Autodesk en Templates\PTN_Part_Library\New_PTN_Part_Library.xlsx"
Dim ExcelApp As Object
Dim opened As Boolean
Dim wb As Object
Dim Six_Digit As String
ExcelApp = GetObject(, "Excel.Application")
opened = False
For Each wb In ExcelApp.workbooks
	If UCase(wb.fullname) = UCase(Filename) Then
		opened = True
		Exit For
	End If
Next
If Not opened Then
	GoExcel.Open("C:\Autodesk en Templates\PTN_Part_Library\New_PTN_Part_Library.xlsx")
	'GoExcel.Open("C:\Users\ef\Desktop\New_PTN_Part_Library.xlsx")
End If
Six_Digit = ExcelApp.ActiveCell.Value
If Six_Digit = "" Then
            Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
End If
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "C:\Autodesk en Templates\PTN_Part_Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
            Dim oFileNameNoExt As String = System.IO.Path.GetFileNameWithoutExtension(oFilename)
            If oFileNameNoExt.Contains(Six_Digit) AndAlso oFileNameNoExt.Length = 11 Then
                        Dim oOptions As Inventor.NameValueMap
                        oOptions = ThisApplication.TransientObjects.CreateNameValueMap
                        oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
                        sFilename = oFilename
                        Exit For
            End If
Next
If sFilename = "" Then
            MessageBox.Show("No matching libary file found.", "iLogic")
            Return
End If
'path from current file
Dim oActiveAssemblyfolder As String = ThisDoc.Path & "\"
'find the postion of the last backslash in the path
Dim FNamePos As Integer = InStrRev(sFilename, "\", -1)
'get the file name with the file extension
Dim oName As String = Right(sFilename, Len(sFilename) -FNamePos)
'get the file name (without extension)
Dim ShortName As String = Left(oName, Len(oName) -4)
'get extension
Dim oExt As String = Right(oName, 4)
Dim oNewName As String = ShortName & "_" & System.DateTime.Now.ToString("yyyyMdHHmmss")
Dim oPathandName As String = oActiveAssemblyfolder & oNewName & oExt
oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = ShortName
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
'Dim oOcc As ComponentOccurrence
'oOcc = oAsmCompDef.Occurrences.Add( _
'oPathandName, oMatrix)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oPathandName)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (37)
Message 21 of 38
bradeneuropeArthur
Step 1:
please start VBA.
with alt f11
Step 2:
Open a new part
save it on your desktop
then reply that you are ready
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 22 of 38
bradeneuropeArthur
step1
new part
save it to desktop
step 2
start VBA
with alt f11
reply ready
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 23 of 38
Ralf_Krieg
Hello
You said, that if you start Inventor as administrator the error disappeared. Can you confirm that Excel is not started elevated? Maybe it is activated in the link options in the compatibility tab.
If I start Excel as Administrator and Inventor as normal user, the error raises. The same behaviour if Inventor is started as administrator and Excel not. The level of UAC seems to make no difference here.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 24 of 38
johan.degreef
Alt+F11 gives this, so I should install it...?
Message 25 of 38
johan.degreef
Installing the VBA part in inventor did not reslove the issue.
Message 26 of 38
johan.degreef
VBA windows open in inventor now when pressing alt+F11, but ilogic code does not run
Message 27 of 38
bradeneuropeArthur
in VBA create a module
and paste this
public sub main
set ExcelApp = GetObject(, "Excel.Application")
end sub
Run VBA code
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 28 of 38
johan.degreef
same error
Message 29 of 38
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 30 of 38
bradeneuropeArthur
Johan,
Does the DrawingList Tool still work?
Because it uses the same principle!
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 31 of 38
johan.degreef
@bradeneuropeArthur wrote:
Johan,
Regards
No error: Apprentice server is not installed.
Altough I did check and inventor View 2021 is installed.
Message 32 of 38
bradeneuropeArthur
Something terribly wrong with your system.
what version of excel are you using?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 33 of 38
johan.degreef
Excel 2019 MSO 64 bit
Message 34 of 38
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 35 of 38
bradeneuropeArthur
try this:
GetObject(, "Excel.Application.19")
Maybe you have more excel versions installed or at least the references!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 36 of 38
johan.degreef
.19, no, but I think i am going to reset my laptop and do a reinstall.
Message 37 of 38
johan.degreef
Indeed, a clean install did resolve all problems
Message 38 of 38
bradeneuropeArthur
after the last windows update I have also some issues.
I have resolved them but it was difficult!
Not always good practice to install windows updates!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
