Error in aream rule when saving assembly
Charlies_3D_T
Charlies_3D_T
I have the following problem. See screenshot for the error message.
If i save the parts in part then i don't have an error. When i update an ass and i save it i get an error on each sheetmetal part. Below is my ilogic.
Hope someon knows the problem.
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
'Check For flat pattern, if none, create one
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Parameter("Lengte") = SheetMetal.FlatExtentsLength
Parameter("Breedte") = SheetMetal.FlatExtentsWidth
Else
End If
DRoam
One of the things you have to think about when writing rules is if it should run on the document the rule stored in, or on the currently-active document. In general, most rules are intended to run on the document the rule is stored in. To make that happen, change this line:
to this:
oDoc = ThisDoc.Document
bradeneuropeArthur
Dim ple As Inventor.Parameter
ple = oCompDef.Parameters.UserParameters.AddByValue("Lengte",1,"mm")
Dim pbr As Inventor.Parameter
pbr = oCompDef.Parameters.UserParameters.AddByValue("Breedte",1,"mm")
oCompDef.Unfold
Else
End If
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
You forgot to add the parameter Lengte and Breedte….
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Charlies_3D_T
@DRoam
Stupid mistake! I had other rules with the same problem!
Thank you for the solution!
