Error Bom.Componentdefinitions
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
Public Sub Main()
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim FirstLevelOnly As Boolean
    If MsgBox("First level only?", vbYesNo) = vbYes Then
        FirstLevelOnly = True
    Else
        FirstLevelOnly = False
    ' Set a reference to the BOM
    Dim oBOM As BOM
    oBOM = oDoc.ComponentDefinition.BOM
    ' Set whether first level only or all levels.
    If FirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = True
    Else
        oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    oBOMView = oBOM.BOMViews.Item("Structured")
    'Initialize the tab for ItemNumber
    Dim ItemTab As Long
    ItemTab = -3
    Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long)
    ItemTab = ItemTab + 3
    ' Iterate through the contents of the BOM Rows.
    Dim i As Long
    For i = 1 To oBOMRows.Count
        ' Get the current row.
        Dim oRow As BOMRow
        oRow = oBOMRows.Item(i)
        'Set a reference to the primary ComponentDefinition of the row
        Dim oCompDef As Inventor.ComponentDefinition
		Try
			oCompDef = oRow.ComponentDefinitions.Item(1)
			Catch
				MsgBox (oRow.ItemNumber)
			End Try
        Dim oPartNumProperty As Inventor.Property
        Dim oDescripProperty As Inventor.Property
        If TypeOf oCompDef Is VirtualComponentDefinition Then
            'Get the file property that contains the "Part Number"
            'The file property is obtained from the virtual component definition
            oPartNumProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Part Number")
            'Get the file property that contains the "Description"
            oDescripProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Description")
        Else
            'The file property is obtained from the parent
            'document of the associated ComponentDefinition.
            oPartNumProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number")
            oDescripProperty = oCompDef.Document.PropertySets _
            'Recursively iterate child rows if present.
            If Not oRow.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oRow.ChildRows, ItemTab)
    Next
    ItemTab = ItemTab - 3
End Sub
This code from the help gives an error on the line with:
Try
Catch
msgbox (oRow.ComponentDefinitions.Count)
gives somtimes "0" for an assembly
End Try
Why is that the case
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Found out why.
Since the implementation of Model States, suppressed components are no longer removed from the Bill Of Material.
They are only indicated with quantity "0".
These return a "oRow.ComponentDefinitions.Count" of "0" ofcourse.
This is very confusing because you don't see this directly during programming.
Still good to learn from this case and maybe it helps others.
Arthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
