Get coordinates of work point at assembly level
Curtis_Waguespack
Consultant Consultant
Message 1 of 17
Curtis_Waguespack
I have a workpoint in a component file that is some unknown levels down in an assembly. I want to get the location of this workpoint relative to the top level assembly. What is the best way to get the coordinates?
Currently I am traversing the assembly and creating a proxy object, but this seems to only give me the correct coordinates down a couple of levels.
My understanding is that a proxy object should get the entire path of the component all the way down the assembly structure, as stated here:
"...A proxy is a reference to an object that exists outside the top-level component, and the proxy defines the full path from the top-level down to the object. The path is made up of a list of occurrences, and the final item in the path is the object itself.  ..." quote from here:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/difference-between-componentoccurren...
So it seems that because I am creating the proxy at the subassembly, at the the level in which I find it as I traverse the components, the proxy does not contain the full path and therefor  doesn't report the correct coordinates.
Thanks in advance.
Curtis
See attached example files ( Inv 2022)
Here the point's coordinates are at 2.222, 1.866, 4.444 in the assembly as shown by the sketch dims
Public Sub Main()
	Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
	Dim oAsmDef As AssemblyComponentDefinition
	oAsmDef = oAsmDoc.ComponentDefinition
	Dim oOccs As ComponentOccurrences = oAsmDoc.ComponentDefinition.Occurrences
	Call TraverseAssembly(oAsmDef, oOccs)
End Sub
Function TraverseAssembly(oAsmDef As AssemblyComponentDefinition, oOccs As ComponentOccurrences)
	Dim oWPProxy As WorkPointProxy 'Proxy
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		Dim oWP As WorkPoint
		For Each oWP In oOcc.Definition.WorkPoints
			If Not UCase(oWP.Name).Contains("TEST") Then Continue For
			Call oOcc.CreateGeometryProxy(oWP, oWPProxy)
			Dim xCoord, yCoord, zCoord As Double
			xCoord = oWPProxy.Point.X
			yCoord = oWPProxy.Point.Y
			zCoord = oWPProxy.Point.Z
			oLine = "X: " & Round(xCoord, 3) & vbLf & "Y: " & Round(yCoord, 3) & vbLf & "Z: " & Round(zCoord, 3)
			Logger.Info(oLine)
			MsgBox(oLine, ,  oWP.Name )
		Next
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			'step into subassembly
			oSubOccs = oOcc.Definition.Document.ComponentDefinition.Occurrences
			Call TraverseAssembly(oAsmDef, oSubOccs)
	Next
End Function
Replies (16)
Message 2 of 17
Curtis_Waguespack
I also get the same results attempting to create a temporary workpoint from a component work point
Public Sub Main()
End Sub
		Dim oTempWP As WorkPoint
			oTempWP = ThisDoc.Document.ComponentDefinition.WorkPoints.AddFixed(oWP.Point)
			oTempWP.name = oWP.Name & "_TEMP"
			xCoord = oTempWP.Point.X
			yCoord = oTempWP.Point.Y
			zCoord = oTempWP.Point.Z
			MsgBox(oLine, , oTempWP.Name)
			oTempWP.delete
		Next
	Next
End Function
Message 3 of 17
JelteDeJong
I tried to open your zip file but it seems broken. can you send it again?
Jelte de Jong
Blog: hjalte.nl - github.com
Message 4 of 17
JelteDeJong
I assume the work point is in a part file. You could search all leaf occurrences. that way you don't need to transfer all sub-assemblies. Something like this:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim workPointProxy As WorkPointProxy
For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences.AllLeafOccurrences
	Try
		If (occ.Suppressed) Then Continue For
		For Each workPoint As WorkPoint In occ.Definition.WorkPoints
			If Not WorkPoint.Name.ToUpper().Contains("TEST") Then Continue For
			occ.CreateGeometryProxy(WorkPoint, workPointProxy)
			Dim xCoord = workPointProxy.Point.X
			Dim yCoord = workPointProxy.Point.Y
			Dim zCoord = workPointProxy.Point.Z
			Dim nl = System.Environment.NewLine
			Dim oLine = String.Format("X: {1}{0} Y: {2}{0} Z: {3}",
						nl, Math.Round(xCoord, 3), Math.Round(yCoord, 3), Math.Round(zCoord, 3))
			MsgBox(oLine)
		Next
	Catch ex As Exception
		MsgBox("exception on occurrence:" & occ.Name)
	End Try
Next
Jelte de Jong
Message 5 of 17
mat_hijs
I believe you will have to create a proxy for each level of the assembly. So if you have a top level assembly containing a subassembly containing a part with the workpoint you'll have to create a proxy of the workpoint in the subassembly and then create a proxy of the proxy in the top level assembly.
Message 6 of 17
mat_hijs
I tried to create a little test to show what I meant and this location seems to be correct. The code I wrote is not elegant in any way and is also not recursive, but it does show how it works.
Here is the code:
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim oOccurrencesLevel2 As ComponentOccurrences = oAsmCompDef.Occurrences
Dim oOccurrenceLevel2 As ComponentOccurrence = oOccurrencesLevel2.Item(1)
Dim oOccurrencesLevel3 As ComponentOccurrences = oOccurrenceLevel2.Definition.Occurrences
Dim oOccurrenceLevel3 As ComponentOccurrence = oOccurrencesLevel3.Item(1)
Dim oWorkPointLevel3 As WorkPoint = oOccurrenceLevel3.Definition.WorkPoints.Item("WPT_Location")
Dim oWorkPointProxyLevel2 As WorkPointProxy
oOccurrenceLevel3.CreateGeometryProxy(oWorkPointLevel3, oWorkPointProxyLevel2)
Dim oWorkPointProxyLevel1 As WorkPointProxy
oOccurrenceLevel2.CreateGeometryProxy(oWorkPointProxyLevel2, oWorkPointProxyLevel1)
MsgBox("X: " & oWorkPointProxyLevel1.Point.X & ", Y: " & oWorkPointProxyLevel1.Point.Y & ", Z: " & oWorkPointProxyLevel1.Point.Z)
Message 7 of 17
Curtis_Waguespack
Hi @JelteDeJong
Thank you for having a look.
I think I have fixed the zip file. I re-uploaded it and it seems to download properly for me now:
https://forums.autodesk.com/autodesk/attachments/autodesk/120/148090/4/WP%20location%202022.zip
Unfortunately, there could be workpoints that I am needing to retrieve in parts an/or assemblies, so All Leaf Occurrences will not work in this case.
Thanks again,
Curtis
Message 8 of 17
Curtis_Waguespack
Hi @mat_hijs
Thank you for your reply.
Creating a proxy for each level will be a challenge since I can not predict the number of levels.
Maybe I can write something to get the level of each found workpoint and then loop and create proxies that many times to get back to the top level. It seems like there should be a cleaner way to do so though.
Thank again,
Curtis
Message 9 of 17
Michael.Navara
You don't need to traverse assembly tree. Just use work point proxy to get coordinates in assembly context
Dim asm As AssemblyDocument = ThisDoc.Document
For Each occ As ComponentOccurrence In asm.ComponentDefinition.Occurrences.AllLeafOccurrences()
	Dim partDef As PartComponentDefinition = occ.Definition
	Dim wp As WorkPoint = partDef.WorkPoints("WP-TEST 55")
	Logger.Debug("Local coords: [{0:N3}, {1:N3}, {2:N3}]", wp.Point.X, wp.Point.Y, wp.Point.Z)
	Dim wpProxy As WorkPointProxy
	occ.CreateGeometryProxy(wp, wpProxy)
	Logger.Debug("Assy coords: [{0:N3}, {1:N3}, {2:N3}]", wpProxy.Point.X, wpProxy.Point.Y, wpProxy.Point.Z)
Next
Message 10 of 17
WCrihfield
Hi @Curtis_Waguespack.  I don't know if you have ever seen these code tools I have posted here on the forums before, but they can be quite useful in situations like this, where there may be an unknown number of levels of an assembly involved, and you need a reference to something deep within the assembly.
To start things off, here is a very simple little function for simply identifying if an object is a 'proxy' or not.  I use this technique in the following solutions.
Function IsProxy(oObj As Object) As Boolean
	If IsNothing(oObj) Then Return False
	If TypeName(oObj).EndsWith("Proxy") Then Return True
	Return False
End Function
Here is a tool for getting the true/native 'source' object from a top level proxy object, even if it represents something that is really many levels deep.
Function GetProxySource(oProxyObj As Object) As Object
	If IsNothing(oProxyObj) Then Return Nothing
	Dim oNativeObject As Object = Nothing
	If TypeName(oProxyObj).EndsWith("Proxy") = False Then
		oNativeObject = oProxyObj
	Else
		oNativeObject = GetProxySource(oProxyObj.NativeObject)
	Return oNativeObject
End Function
And here is a tool for the opposite direction.  You can input a lower level proxy object, that may be many levels own, then get its 'top level' proxy object in return.
Function GetTopLevelProxy(oInputObj As Object) As Object
	If IsNothing(oInputObj) Then Return Nothing
	'if it is not already a Proxy object, return original input object
	If TypeName(oInputObj).EndsWith("Proxy") = False Then Return oInputObj
	'possible input proxy objects
	'EdgeProxy, FaceProxy, VertexProxy
	'MeshEdgeProxy, MeshFaceProxy, MeshVertexProxy
	'WorkAxisProxy, WorkPlaneProxy, WorkPointProxy, WorkSurfaceProxy
	'Do all have a ContainingOccurrence property? - Yes
	'Do all have a Parent property, and if so, what do they return? - Yes
	' - EdgeProxy, FaceProxy, & VertexProxy Parent returns SurfaceBody
	' - All work features Parent returns ComponentDefinition
	'All do have the NativeObject property, which should be obvious. - Yes
	Dim oParentOcc As ComponentOccurrence = oInputObj.ContainingOccurrence
	Dim oNextLevelUpProxy As Object = Nothing
	oParentOcc.CreateGeometryProxy(oInputObj, oNextLevelUpProxy)
	If oParentOcc.ParentOccurrence Is Nothing Then 'it is top level component
		Return oNextLevelUpProxy
	Else 'this proxy's containing component is not a top level component
		GetTopLevelProxy(oNextLevelUpProxy)
End Function
 And finally, another little tool, that is not 'proxy' related, but could be useful in the same overall code solution.  When 'climbing the ladder' in an assembly structure, to get a reference to the 'proxy' of an object at the 'parent' level, you will need to know when you get to the top level, so you know when to stop the loop/cycle.  This is just a 1-liner embedded in a Function.
Function IsTopLevelComponent(oComp As ComponentOccurrence) As Boolean
	If IsNothing(oComp) Then Return False
	If oComp.ParentOccurrence Is Nothing Then Return True
	Return False
End Function
Maybe these tools will help with your challenge here.
Wesley Crihfield
(Not an Autodesk Employee)
Message 11 of 17
Curtis_Waguespack
Hi @Michael.Navara,
Thank you for the reply.
Unfortunately, I can't use All Leaf Occurrences because the workpoints might be in a subassemblies and/or parts. And I can not call the workpoints by name as they are unknown.
So I will need to traverse the assembly to find them, and then create the proxy. And therein lies the rub, in that the proxy get created at the level that the point is found.
Thanks again,
Curtis
Message 12 of 17
Curtis_Waguespack
Hi @WCrihfield,
Thanks for taking a look.
I only had a brief look at the functions you provided for the moment. I'll give them a closer look later when I have time, but I think I might see a way to use one of these to round up all the proxies created as I traverse the assembly and then create proxies of them at the top level to get their location at the top.
Thanks again,
Curtis
Message 13 of 17
jjstr8
@Curtis_Waguespack :  A quick test showed me that you need to traverse the occurrences tree solely, not occurrences in the definitions.  In other words, iterate Occurrences from the top level and SubOccurrences from each top level occurrence and sub-occurrences downward.  That will give you an occurrence that is in the context of the top level assembly.
Message 14 of 17
JelteDeJong
What about looping over all reference documents to find the document with the point? Then find the occurrence that belongs to the document. Something like this:
Dim foundWorkPoint As WorkPoint
Dim foundDoc As Document
For Each refDoc As Document In doc.AllReferencedDocuments
	For Each workPoint As WorkPoint In refDoc.ComponentDefinition.WorkPoints
		foundWorkPoint = WorkPoint
		foundDoc = refDoc
		Exit For
	Next
Next
Dim occs = doc.ComponentDefinition.Occurrences.AllReferencedOccurrences(foundDoc)
If (occs.Count > 1) Then
	MsgBox("Multiple docs found wit the workpoint!")
Dim occ = occs.Item(1)
occ.CreateGeometryProxy(foundWorkPoint, workPointProxy)
MsgBox(oLine)
Jelte de Jong
Message 15 of 17
JelteDeJong
After writing the last post I thought of this blog post "Universal occurrence search function" that I wrote some time ago and wanted to check if it would help you. But I came to the conclusion that it would not work. So I thought it would be cool to make a "Universal occurrence search function" that would work. Below is the result but I'm not so sure it's better.  What do you think?
Sub Main()
	Dim occs = FindAllWhere(doc, AddressOf HasWorkPointWithNameTest)
	Dim occ = occs.First
	Dim workpoints As WorkPoints = occ.Definition.WorkPoints
	Dim filterdWorkpoints = workpoints.Cast(Of WorkPoint).
		Where(Function(wp) wp.Name.Contains("TEST"))
	If (filterdWorkpoints.Count > 1) Then
		MsgBox("Multiple workpoint found in occ!")
	occ.CreateGeometryProxy(filterdWorkpoints.First, workPointProxy)
	MsgBox(oLine)
End Sub
Public Function HasWorkPointWithNameTest(doc As Document) As Boolean
	Dim workpoints As WorkPoints = doc.ComponentDefinition.WorkPoints
	Dim points = workpoints.Cast(Of WorkPoint).Where(Function(wp) wp.Name.Contains("TEST"))
	Return (points.Count <> 0)
End Function
Public Function FindAllWhere(doc As AssemblyDocument,
			predicate As Func(Of Document, Boolean)) As IEnumerable(Of ComponentOccurrence)
	Dim docList As IEnumerable(Of Document) = doc.
		AllReferencedDocuments.Cast(Of Document).
		Where(predicate)
	Dim occList As New List(Of ComponentOccurrence)
	For Each refDoc As Document In docList
		Dim occs = doc.ComponentDefinition.Occurrences.AllReferencedOccurrences(refDoc).Cast(Of ComponentOccurrence).ToList()
		occList.AddRange(occs)
	Next
	Return occList
End Function
Jelte de Jong
Message 16 of 17
Curtis_Waguespack
@jjstr8
That was it! 👍
Thanks!!!
Public Sub Main()
End Sub
			MsgBox(oLine, , oWP.Name)
		Next
			oSubOccs = oOcc.SubOccurrences
	Next
End Function
Message 17 of 17
Curtis_Waguespack
@JelteDeJong
Thanks those work really well!
