dwg to pdf ilogic help
hi guys. i have an issue i think ilogic can help me with but i am unsure.
i have a dwg with 20 pages and i need to export all sheets to pdf but i need each sheet to be on its own pdf file. so i will end up with 20 pdfs at the end.
also on eash sheet i have a drawing expresion of "dwg_name" and this is what i want to call each pdf file.
can anyone help me or point me in the correct direction thanks
bradeneuropeArthur
Hi.
Use this code and first activate the sheet then export each sheet with a different pdf name like sheet 1 sheet 2 etc till 20.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
forums.autodesk.com/t5/inventor-customization/pdfaddin-option-quot-launch-viewer-quot-true-or-false-not-set-in/td-p/7604075
I am not at my desk. Later I can be more specific
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
I have written and checked the following code for you, for VBA and Vb.net:
Per sheet 1 pdf file in your C:drive:
Public Sub PublishPDF()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As DrawingDocument
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    Dim sh As Sheet
    Dim i As Integer
    i = 0
For Each sh In oDocument.Sheets
On Error Resume Next
    i = i + 1
    Set sh = oDocument.Sheets.Item(i)
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        oOptions.Value("All_Color_AS_Black") = True
        oOptions.Value("Sheet_Range") = i
    'Set the destination file name
    oDataMedium.FileName = "C:\test" & i & ".pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
    If Error Then
    Err.Clear
    Next
End Sub
 For I-logic the following Code:
'Public Sub PublishPDF()
    Dim sh As Sheet
    Dim i As Integer
    i = 0
    i = i + 1
    oDataMedium.FileName = "D:\test" & i & ".pdf"
    'Publish document.
    Next
'End Sub
If you have any questions please ask....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Sorry I have made a mistake;
The code is not printing all sheets separate.
The following code does!
    Dim sh As Sheet
    Dim i As Integer
    i = 0
Try
	Catch
		End Try
    i = i + 1
        oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintSheetRange'
	oOptions.Value ("Custom_Begin_Sheet") = i
        oOptions.Value("Custom_End_Sheet")=i
    'Publish document.
    Next
'End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
