automatically create a second sheet processing
S_May
Mentor Mentor
Message 1 of 12
S_May
Hello together,
is it possible to automatically create a second sheet processing next to the drawing with ilogic?
Replies (11)
Message 2 of 12
bradeneuropeArthur
I think not.
What about printing the sheet etc?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
S_May
we would need in the company the sheet metal next to the sheet only for the laser
Message 4 of 12
bradeneuropeArthur
Why do you need a border and header than?
You or not printing or exporting!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
dgreatice
You title change become how to export to DWG/DXF with scale 1 : 1 to Model View at AutoCAD.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 6 of 12
S_May
  1. idw save => second processing automatically next to the sheet (trigger of ilogic is the save)
  2. jobserver automatically generates dxf
  3. dxf are needed for lasers
  4. We then do this automatically at 75,000 idw in the system (PDM PROFILE)
Message 7 of 12
bradeneuropeArthur
Why don't you use the dxf file of the sheet metal part themselves. It is easier to create dxf file of the sheet metal part *.ipt by jobserver.
If help needed please let me know
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 12
Jon.Dean
Hi @S_May,
When you create a flat pattern of your sheetmetal part, you can right click on the flat pattern view and select "Export face as...".
This allows you to create a DXF file of just the flat pattern and does not include the drawing border and title block.
If you are sending to a laser cutter, then this method would seem to be a better method.
Cheers
Jon.
Jon Dean
Message 9 of 12
S_May
Hi @Jon.Dean,
the dxf are generated by the PDM system (not by hand)
Here is the code that creates the second flat sheet next to the sheet.
Sub CreateFlatPatternView()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim tmpView As DrawingView
For Each tmpView In oSheet.DrawingViews
If tmpView.Name = "LASER" Then
MsgBox ("Ansicht LASER existiert bereits. Code wird verlassen.")
Exit Sub
Next
' Create a new NameValueMap object
Dim oBaseViewOptions As NameValueMap
Set oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Set the options to use when creating the base view.
Call oBaseViewOptions.Add("SheetMetalFoldedModel", False)
' Open the sheet metal document invisibly
Dim oModel As Document
Set oModel = oSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument 'ThisApplication.Documents.Open("C:\temp\SheetMetal.ipt", False)
' Create the placement point object.
Dim oPoint As Point2d
Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width + 10, oSheet.Height / 2)
' Create a base view.
Dim oBaseView As DrawingView
Set oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 1, _
kDefaultViewOrientation, kHiddenLineRemovedDrawingViewStyle, _
, , oBaseViewOptions)
oBaseView.Name = "LASER"
End Sub
Ein Danke an @Dennis.Ossadnik
Message 10 of 12
bradeneuropeArthur
Misunderstood.
You needed a second DRAWING VIEW next to your sheet!
No second SHEET!
you wrote:
is it possible to automatically create a second sheet.........
Good to know that it is solved
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
S_May
Message 12 of 12
dgreatice
or maybe.
create DrawingView (Folded) with new sheet Smiley Indifferent
