dwf file
dwf file
GosponZ
Message 1 of 8
dwf file
GosponZ
On some our files DWF files are not published very well. Lines are missing. Does anybody has same problem or how to solve this?
 Autodesk?
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GosponZ,
Can you please provide sample drawing to publish dwf file?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
GosponZ
Sorry took me so long. No I can't post any file but very interesting is that is not all the time. Most of files are just Good but some just mess like that one above. I was thinking if there is any kind set up for dwf file so they can be good all the time.
Thank you
Message 4 of 8
bradeneuropeArthur
Are these inventor dwg files?
Are you publishing form Vault?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 8
GosponZ
Yes Inventor dwg and published on check in
Message 6 of 8
bradeneuropeArthur
Check your DwgTrueviewSettings for vault.
C:\Program Files\Autodesk\Vault ?????\Explorer\TrueViewSetup.dwg
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
GosponZ
I Changed to 0 layer. Looks good. I do not know if that fixed problem because as I said not on all files happened. But anyway thank you for your help.
Message 8 of 8
bradeneuropeArthur
Good to hear that it is solved for now.
Thanks are appreciated.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
