Drawing Sheet - BaseView Creation VB
NachoShaw
Advisor Advisor
Message 1 of 8
NachoShaw
Hi
Im sure i had this working before but i seem to have forgotten.....
Using code, i am adding a drawing sheet to a drawing then adding a baseview. I cant use a SheetFormat because we dont work that way. Instead, we just use the built in Create Sheet button method. This will create a new sheet based on the currently active sheet.
How can i do this in code?
Basically, our template has 3 standard sheets
  • Front
  • Assy
  • Part
I need to be able to create a sheet using the built in sheets based on the type. I have the type code, i just cannot get the correct drawing sheet. currently, its just a blank sheet with no border or titleblock...
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (7)
Message 2 of 8
bradeneuropeArthur
This Code is working, but need to investigate the titleblock add function.
This seems to be a bug in inventor.
        Dim a As Inventor.Application
        a = _InvApp
        Dim b As DrawingDocument
        b = a.ActiveDocument
        Dim sh As Sheet
        sh = b.ActiveSheet
        Dim shts As Sheets
        shts = b.Sheets
        Dim newsh As Sheet
        newsh = shts.Add
        Dim bo As BorderDefinition
        bo = b.BorderDefinitions.Item(2)' REPLACE WITH THE NAME OF THE BORDER YOU NEED
        Dim He As TitleBlockDefinition
        He = b.TitleBlockDefinitions.Item(1)' REPLACE WITH THE NAME OF THE TITLEBLOC YOU NEED
        newsh.Activate()
        Call newsh.AddBorder(bo)
        newsh.Activate()
        Dim titlebl As Inventor.TitleBlock
        titlebl = newsh.AddTitleBlock(He)
    End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
woodstylee3
Does your titleblock have prompted entries?
If this is the case I believe you have to pass in an array of the values for the entries when the titleblock is added. Will check my code and reply, but worth a search on this.
Message 4 of 8
bradeneuropeArthur
I read thst this is a known issue for Autodesk.
I gave already searched for that.
Do you have a solution for this line of code than?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
NachoShaw
Hi
There are not any prompted entries at the moment but i cant rule that out for the future. I wrote some code a while ago that adds the titleblock and border definition and handles prompted entries but i was hoping for a more simple solution like the built in Inventor one. When i click that, it literally adds the sheet with everything on it.
I suppose i could just get the definitions from the existing sheets and use the same settings. the sheet positions are always the same
i will do some coding tomorrow and see what i can come up with
cheers
Nacho
Message 6 of 8
bradeneuropeArthur
This code adds the sheet in the current format:
Public Sub AddSheet()
Dim oCDef As ControlDefinition
Set oCDef = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingNewSheetCtxCmd")
oCDef.Execute
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
NachoShaw
Hi
Yes i have tried that before but its not exactly the best method. for one, i cant access the prompted entries by code and another is i still cant access the choice of sheets. but yes, your suggested version will simply add a sheet based on the currently active sheet.
Is there not a method of just selecting the sheet number and adding a new version of it?
cheers
Nacho
Message 8 of 8
bradeneuropeArthur
'YOU CAN ACCES THAT AFTERWARDS VIA CODING
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
