MultiValue
MultiValue
martinhoos
MultiValue
martinhoos
i try to create MultiValue Lists that depend on other MultiValue Lists. Long Story short, i have a form where i can change material "Kupfer" and "Aluminium". If i choose "Kupfer" the MultiValue of "rm_rohr_typ" should be "1_XXX, 2_XXX, 3_XXX and 4_XXX". If i choose "Aluminium the MultiValue of "rm_rohr_typ" shouldt be "1_YYY, 2_YYY and 3_YYY".
The rule should check, if the user parameter exists, if yes only the MultiValue should change. If not, the user parameter  should create with the MultiValue.
If this works, i can complete the rule with additional IF THEN - For example: IF Kupfer and 1_XXX use blue, IF Kupfer and 2_YYY use green....
Thanks in advance.
Regards Martin
iLogicVb.UpdateWhenDone = True
oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
Try
	'Change value of param
		Parameter("rm_rohr_material") = "Kupfer"
	Catch
	'Create Param as it doesn't exist
	oParameter=oMyParameter.AddByValue("rm_rohr_material", "Kupfer", UnitsTypeEnum.kTextUnits)
	Parameter.Param("rm_rohr_material").Comment = "Rohmaterial Kupfer"
	MultiValue.SetList("rm_rohr_material", "Kupfer", "Aluminium")
	End Try
If rm_rohr_material = "Kupfer" Then
Try
	Parameter("rm_rohr_typ") = "1_XXX"
	Catch
	oParameter=oMyParameter.AddByValue("rm_rohr_typ", "1_XXX", UnitsTypeEnum.kTextUnits)
	Parameter.Param("rm_rohr_typ").Comment = "Rohrleitungstyp"
	MultiValue.SetList("rm_rohr_typ", "1_XXX", "2_XXX", "3_XXX", "4_XXX")
	End Try
Else If rm_rohr_material = "Aluminium" Then
Try
	Parameter("rm_rohr_typ") = "1_YYY"
	Catch
	oParameter=oMyParameter.AddByValue("rm_rohr_typ", "1_YYY", UnitsTypeEnum.kTextUnits)
	MultiValue.SetList("rm_rohr_typ", "1_YYY", "2_YYY", "3_YYY")
	End Try
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Try the below 2 iLogic code to create multivalue list based on parameter.
Rule0: This rule is to create 2 MultiValue list
Try
Catch
End Try
Rule1: This rule is to update MultiValue list based on user parameter selection.
A detailed procedure is prepared as shown below.
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
chandra.shekar.g
Autodesk Support
Autodesk Support
CHANDRA SHEKAR G
Developer Advocate
martinhoos
Hello Chandra, thats it - thank you very much for your tip!
regards
Martin
