Drawing BOM Indented?
chayman
chayman
When inserting a BOM in a drawing, is there a way for there to be a visual child/parent relationship?
At the moment the only visual relationship is as follows with no indentation:
1.1
1.2
2
2.2
Is there a way to have indentation like:
1
     1.1
     1.2
2
     2.1
     2.2
MechMachineMan
Sub Main()
    delimchar = "."
    Dim oPartsList As PartsList
    oPartsList = ThisDoc.Document.ActiveSheet.PartsLists.Item(1)
    For Each oRow in oPartsList.PartsListRows
        oCurRow = TRIM(oRow.Item(1).Value)
        oSpcCount = Len(oCurRow) - Len(oCurRow.Replace(delimchar, ""))
        oRow.Item(1).Value = Space(oSpcCount) & oCurRow
    Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
chayman
@MechMachineMan
Thanks for you quick response. I have created a rule called "BOM" and inserted the parts list in the drawing for the respective assembly. I run the rule, yet nothing happens to the BOM.
It is still:
1
1.1
1.2
etc
MechMachineMan
Because you have your parts list style set to "Centered" for the item number column.
Indentation only works with a left aligned column....
Edit Parts List
Format Column
Click the box to left align the item number column.
Justin K
MechMachineMan
Or use this code with the added justification in as a bandaid fix, instead of properly changing the partslist style to match what you want...
Sub Main()
    delimchar = "."
oPartsList.PartsListColumns.Item(1).ValueHorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft
For Each oRow in oPartsList.PartsListRows oCurRow = TRIM(oRow.Item(1).Value) oSpcCount = Len(oCurRow) - Len(oCurRow.Replace(delimchar, "")) oRow.Item(1).Value = Space(oSpcCount) & oCurRow Next End Sub
Justin K
Hi There, Thank you for your input and help so far. I tried using the code but got an error. Please see the attachment. I would greatly appreciate if you can help debug it.
Many Thanks.
elelieveld
If you want the indent to be more pronounced visually, change:
to
 oSpcCount = (Len(oCurRow) - Len(oCurRow.Replace(delimchar, ""))) * 5
