iLogic - for loop ends earlier than it has to
Dear Fellows,
Do You have any idea why this loop always ends with increment No. of m=11, instead of moving forward untill variable m=NoB  in a first "while" loop?
If PlatformType = "Right" Then
	For m=1 To 30
		While m <= NoB
			Try
				Feature.IsActive("RevolutionSrf" & m) = False
				Feature.IsActive("RevolutionSrf-" & m) = False
				Feature.IsActive("RightRevolutionSrf" & m) = True
				MessageBox.Show(m, "Title")
			Catch
			End Try
		m=m+1
		End While
		While m > NoB And m <= 30
			Try
				Feature.IsActive("RightRevolutionSrf" & m) = False
			Catch
			End Try
		m=m+1
		End While
	Next
HermJan.Otterman
What is the number of Nob?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
NoB is variable, for this moment it is 25
HermJan.Otterman
when I try the loop it runs fine.
I think that the problem is that when m gets greater then 11 there is some error with the feature.isActive lines so it will go to the Catch and not to your Messagebox line.
to test, put the messagebox line :
MessageBox.Show(m, "M Title")
 right after the first "while" line and you will see that is is counting up
I hope this helps
Herm Jan
