Drag & Drop into assembly inventor not working
Hello. I have created a plugin for inventor (vb net) .
From a grid my plugin drag and drop to open a part or assembly . This works.
If I insert a part in an assembly it is not working .
I have to use some other method to insert drag and drop a part/assembly into an assembly ?
Thank you in advance
Jef_E
Could you please show your code that does the drag drop?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
