Set Virtual Component Material - INV 2015
I'm creating some virtual components and trying to set the material property for each one. It either doesn't work, the property value doesn't change, or it crashes with an "unspecifed error". The interesting part is; I can set any iProperty and even create custom iProperties but, cannot set the material. What can I do to resolve this issue.
Eric....
public bool SetVirtualCompMaterial(ComponentOccurrence _occ, string _matlName)
            // Validate the occurrence is virtual.
            if (!(_occ.Definition is VirtualComponentDefinition)) return false;
            // Set a reference to the virtual component definition
            VirtualComponentDefinition _vCompDef = (VirtualComponentDefinition) _occ.Definition;
            // Return if the virtual component definition is null.
            if (_vCompDef == null) return false;
            // Set a reference to the material asset.
            Asset _materialAsset = _getMaterialAsset(_matlName);
            // Return if the material asset cannot be set.
            if (_materialAsset != null)
                try
                    _vCompDef.Material.Name = _materialAsset.DisplayName;
                    return true;
                catch (Exception)
                { return false; }
            // Assign the material from the provided string
            // because a material in the assets wasn't found.
            try
            {   _vCompDef.Material.Name = _matlName;}
            catch (Exception)
            { return false; }
            return true;
xiaodong_liang
Autodesk Support
Autodesk Support
firstly, the usage of setting display name of a material is NOT a correct way to change a material. You need to change the object 'material'.
But, Document.Material has been retired since 2014. Currently it is a hidden methods for compatibility. Normally, we use MaterialAsset or AppearanceAsset to update the material/appearance. While it looks these new methods are not working well with virtual component. So I have to turn back to recommend the old way below.
Sub changeVCompM()
 Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    Dim oAssDef As AssemblyComponentDefinition
    Set oAssDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim oM As Matrix
    Set oM = ThisApplication.TransientGeometry.CreateMatrix
    Dim oV1 As ComponentOccurrence
    Set oV1 = oAssDef.Occurrences.AddVirtual("111", oM)
    oV1.Definition.Material = asmDoc.Materials(4)
    Dim oV2 As ComponentOccurrence
    Set oV2 = oAssDef.Occurrences.AddVirtual("222", oM)
    oV2.Definition.Material = asmDoc.Materials(5)
End Sub
