Adding a drop down list in a Form
tschaeferZNBXX
Advisor Advisor
tschaeferZNBXX
I am new to using these Forms in iLogic but was curious if anyone could tell me how to have a field that is populated from a drop down list?
Also looking how to add buttons and conditions on fields such as "Read Only".
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
mwighton
adding a drop down selection list to a form you need a user text parameter first and make a multi-variable list then add that parameter to the form.
As for adding buttons not sure about that one.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
tschaeferZNBXX
Would this be done using an iLogic rule? Sorry still a little new at this.
*AU Speaker 2018*
* AU Speaker 2017 *
mwighton
No. In the parameters window or add the user parameter. And then in the form editor you drag and drop that parameter to the form.
Sent from my iPhone
God Bless
Mwighton
BrandonBG
