Difference between common .iam file from a Factory Design Utility .iam
gustavo.cassel
Message 1 of 1
gustavo.cassel
I want to know all the differences between these 2 types of files.
As I know, in the .ipt file there is the SubType property which is read and write wich can modify the document from a part to a sheet metal file.
When I convert an common assembly to a welded one, the SubType changes.
I want a way to precisely get if a .iam file is a Factory Design Utility file with VBA/VB.NET or C#.
Like the attached screenshot.
Replies (0)
