Trouble With iLogic Referencing Excel - Unable to Cast COM Object
e_frissell
e_frissell
Having some trouble with a BOM export and I'm not really sure where this is going wrong.  Below is the error I get when running the iLogic that utilizes a reference to Excel.  I don't want to use the iLogic built in GoExcel because it lacks usage.  At the minute my script is just trying to open the file, but constantly errors out.  If anyone has any suggestions I'd appreciate it.
AddReference "microsoft.office.interop.excel.dll"
Imports XL = Microsoft.Office.Interop.Excel
Sub Main()
' https://clintbrown.co.uk/2019/09/21/bom-export-with-ilogic/
	'Adapted from Inventor API Samples by Clint Brown @ClintBrown3D
	'iLogic code Originally posted at https://clintbrown.co.uk/bom-export-with-ilogic
	Dim oDoc As Document
	oDoc = ThisDoc.ModelDocument
	'Ensure that we are in an Assembly file - Exit if not
	If oDoc.DocumentType = kPartDocumentObject Then
		MessageBox.Show("You need to be in an Assembly to Export a BOM", "@ClintBrown3D iLogic")
		Return
	oDoc = ThisApplication.ActiveDocument
	Dim oBOM As BOM
	oBOM = oDoc.ComponentDefinition.BOM
	Dim projectNumber As String = Left(oDoc.DisplayName, 4)
	Dim pathMod As String = ""
	Dim oPath As String = System.Environment.GetFolderPath(Desktop) & "\Export BOMs\" & projectNumber & "\"
	If Not System.IO.Directory.Exists(oPath) Then
	    System.IO.Directory.CreateDirectory(oPath)
	Dim refDoc As Document
	Dim exportVer1, exportVer2, exportVer3, exportVer4, fileName As String
	exportVer1 = "Export All BOMS for Epicor"
	'exportVer2 = "Export Project BOMS for Epicor"
	'exportVer3 = "Export Single Level Structured BOM"
	'exportVer4 = "Parts Only - (Shows components in a flat list)"
	'You can change the output path by editing CSVpath below - by default the path is the same as the assembly file
	'CSVpath = ("C:\Inventor\") 'If you change the path, remember to keep a \ at the end
	CSVpath = oPath
	'Get user input for Export Type:
	Dim MyArrayList As New ArrayList
	MyArrayList.Add("")
	MyArrayList.Add(exportVer1) ' All BOMS
	'MyArrayList.Add("")
	'MyArrayList.Add(exportVer2) ' Project BOMS
	'MyArrayList.Add(exportVer3) ' Single Level BOM
	'MyArrayList.Add(exportVer4) ' Parts Only
	ClintsBoMExporter = InputListBox("Choose a BoM type to Export: " & ClintBrown3D , MyArrayList, d0, Title := "@ClintBrown3D: BoM Export ", ListName := "BoM Type")
	If ClintsBoMExporter = exportVer1 Then : GoTo GoEpicorExport : End If
	If ClintsBoMExporter = exportVer2 Then : GoTo GoProjectBOMExport : End If
	If ClintsBoMExporter = exportVer3 Then :GoTo GoAllLevelsExport : End If
	If ClintsBoMExporter = exportVer4 Then : GoTo GoPartExport : End If
	If ClintsBoMExporter = "" Then : Return : End If
	'STRUCTURED BoM ALL LEVELS:
	GoAllLevelsExport:
	' the structured view to 'all levels'
		oBOM.StructuredViewFirstLevelOnly = False
	' Make sure that the structured view is enabled.
		oBOM.StructuredViewEnabled = True
		Dim oStructuredBOMView As BOMView
		oStructuredBOMView = oBOM.BOMViews.Item("Structured")
	' Export the BOM view to an Excel file
		fileName = CSVpath + pathMod + ThisDoc.FileName(False) + "-Export"+ ".xls"
		oStructuredBOMView.Export(fileName, kMicrosoftExcelFormat)
	GoTo GoLaunch :
	' Export project BOMS
		MsgBox("Not ready")
	Exit Sub
        ' Error's in this function
	'STRUCTURED BoM for Epicor
	GoEpicorExport :
	oBOM.StructuredViewFirstLevelOnly = True
	fileName = CSVpath + ThisDoc.FileName(False) + "-Epicor" + ".xls"
		Dim refname As String
		Dim refBom As BOM
		'Dim excelApp As XL.Application
		For Each refDoc In oDoc.AllReferencedDocuments
			If refDoc.DocumentType = kassemblydocumentobject
				refname = Left(refDoc.DisplayName, Len(refDoc.DisplayName) -4)
				If InStr(Left(refname, 4), "-") > 0 Then
					Continue For
				refBom = refDoc.ComponentDefinition.BOM
				refBom.StructuredViewFirstLevelOnly = True
				refBom.StructuredViewEnabled = True
				oStructuredBOMView = refBom.BOMViews.Item("Structured")
				fileName = CSVpath + refname + "-Epicor" + ".xls"
				'GoExcel.Open(fileName)
				Dim excelApp As XL.Application = CreateObject("Excel.Application")
				Dim oWB As xl.Workbook '= excelApp.Workbooks.Open(fileName)
				oWB = excelApp.Workbooks.Open(fileName)
				'Dim oWS As xl.Worksheet = oWB.Worksheets("Sheet1")
				'excelApp = CreateObject("Excel.Application")
				'Dim excelApp = CreateObject("Excel.Application")
				'excelWorkbook = excelApp.Workbooks.Open(fileName)
				excelApp.Visible = True
				excelApp.DisplayAlerts = False
				'oWS.Columns(1).Delete
				'End With
				excelApp.Workbooks.Close
		Next
	GoTo Golaunch:
	'PARTS ONLY BoM
	GoPartExport:
		oBOM.PartsOnlyViewEnabled = True
		Dim oPartsOnlyBOMView As BOMView
		oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
		MsgBox(CSVpath + ThisDoc.FileName(False) + ".xls")
		fileName = CSVpath + ThisDoc.FileName(False) +"-Parts" + ".xls"
		oPartsOnlyBOMView.Export (fileName, kMicrosoftExcelFormat)
	GoTo GoLaunch:
	'Get user input - do you want to see the BoM?
	GoLaunch:
		'i = MessageBox.Show("Preview the BOM?", "@ClintBrown3D iLogic", MessageBoxButtons.YesNo)
		'If i = vbYes Then : launchviewer = 1 : Else : launchviewer = 0 : End If
		launchviewer = 0
		If launchviewer = 1 Then ThisDoc.Launch(CSVpath + ThisDoc.FileName(False) + ".xls")
		Exit Sub
End Sub
Curtis_Waguespack
A.Acheson
Hi @e_frissell
I would suggest to use option Explicit On to check for undeclared objects. Next ensure you are reading a file path that makes sense, check with message box /logger statement. Is you excel extension .xlsx or .xls?  I would declare and set the excel application before you process any document loops. Can you share the more info tab of error message?
Regards
Alan
e_frissell
@A.Acheson here's the second page of the error
Good idea on declaring and setting the excel object prior to the loop.  I'd be surprised if that solved the problem but at the very least it's good practice
e_frissell
Ugh, ran perfectly on a co-workers computer, that issue is seeming more and more like the problem
