Unable to add Attributesets using ApprenticeServer
lmc.engineering
lmc.engineering
Hi All,
I'm attempting to add an attributeset to a document using Apprentice, however, I am getting a System.Runtime.InteropServices.COMException when it comes to adding it. As below:
 Code as follows:
        Dim m_ApprenticeApp As ApprenticeServerComponent = New ApprenticeServerComponent()
        Dim doc As ApprenticeServerDocument
        Dim ffn As String = "C:\temp\Part1.ipt"
        doc = m_ApprenticeApp.Open(ffn)
        Dim NameOfNewPS As String = "MyNewSet"
        Dim oNewPS As AttributeSet
        If doc.AttributeManager.FindAttributeSets(NameOfNewPS).Count > 0 Then
            ' if the set exists aleady
            oNewPS = doc.AttributeSets(NameOfNewPS)
        Else
            ' add a new one
            oNewPS = doc.AttributeSets.Add(NameOfNewPS)
I have it set to compile using x64, and have reference to the autodesk.inventor.interop. I should note that I can add iProperties with no issues using this:
        Dim iPropSet As Inventor.PropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
        Dim prop As Inventor.Property = Nothing
        Dim PropName As String = "Test"
        Dim found As Boolean = False
        For Each prop In iPropSet
            Debug.WriteLine(prop.Name)
            If prop.Name = PropName Then
                found = True
                Exit For
        Next
        If Not found Then
            prop = iPropSet.Add("1234", "Test")
        doc.PropertySets.FlushToFile()
This link confirms attributes are read/write and gives an example. I can't seem to figure out where it's going wrong at my end. Can anyone shed any light?
Regards
WCrihfield
Hi @lmc.engineering.  I do not use Apprentice Server, so this is just an educated guess, but have you tried declaring the 'oNewPS' variable As Inventor.AttributeSet, instead of just AttributeSet.  I know that sometimes when other references/Imports are involved, sometimes object Types can get misunderstood.  One good example is the TextBox object.  There is an Inventor.TextBox, and there is a System.Windows.Forms.TextBox, and that has always required the additional specification when declaring the variables.  And I know that there are many VB objects with 'Attribute' as part of their Type name, but not sure if AttributeSet is a specific one though.
Wesley Crihfield
(Not an Autodesk Employee)
lmc.engineering
Hi @WCrihfield
Thanks for your reply.
Sadly that had no effect on the issue. This one has got me stumped.
