Apprentice not Recognizing File in BOM
ChristiPedersen
ChristiPedersen
We have 1 assembly that apprentice completely ignores when reading the BOM but its clearly there when viewing the BOM in Inventor.  We cannot understand why.  This is an iassembly and we have tried regenerating it which did not help.  "Inventor BOM" attachment shows we have 22 items at the ship level.  "Code" attachment shows "obomrows.count" is only reading 21.  Any help is greatly appreciated.  We have never had this issue come up.  Although we did just move from 2020 to 2022 and this assembly probably hasn't been used in 2022.  We have not had this issue with any other assemblies in 2022.
WCrihfield
Hi @ChristiPedersen.  I do not use Apprentice, so this is just an educated guess, but you may have to make sure that every file involved has been migrated to the new 2022 version.  That is usually just as simple as opening the file, then saving it, then closing it again.  I believe I recall that Apprentice does not like working with files that have not been migrated to the current level yet.  Just a thought.
Wesley Crihfield
(Not an Autodesk Employee)
ChristiPedersen
Thank you for reading this and your suggestion.  I thought that also so I made sure to migrate it, even regenerating the whole table.  Same result.  Its very strange.
