Deveopertools.msi does not install with Visual Studio VC 2022
oransen
oransen
I have
Microsoft Visual Studio Professional 2022 (64-bit) - Current Version 17.1.0
but when I click to install the developer tools I get this message:
Accepted solutions (3)
bradeneuropeArthur
please see this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Developertools-msi...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
oransen
Thanks for the link. I'm currently using VS 2022 with Inventor 2021 but I had been using the rxinventor.tlb files for Inventor 2019.
I'll reinstall VS2019 and then use those files again.
Is there a reason that VS2022 is not supported?
TIA,
Owen
Frederick_Law
VS2022 should be able to use those files.
As long as you can unpack and copy them to correct folders.
Took me a while to setup Templates in VS2022 Community.
oransen
I'd like to accept your solution too, but there's no button for it. Thanks anyway!
oransen
Just in case anyone else has a similar question I've added instructions to my Inventor C++ programming help file:
http://www.ransensoftware.com/Inventor-CPP/index.html
Look for Visual Studio in the index or contents...
