Determine if Drawing Dimension is Broken
Maxim-CADman77
Advisor Advisor
Message 1 of 14
Maxim-CADman77
I'd like to know the way to determine if particular Drawing Dimension is Broken.
I mean those dimensions crossing View-Break sign like this:
For now I don't even see any simple way to get the name of a DrawingView the Dimension belongs to.
Please vote for Inventor-Idea Text Search within Option Names
Replies (13)
Message 2 of 14
Maxim-CADman77
Inventor itself can determine it (judging by the display option in dimension style settings):
Message 3 of 14
tobias.orlow
Hi @Maxim-CADman77 ,
You should be able to identify such dimension lines by querying the (Get/Set) ShowBreakSymbol() boolean on the DimensionStyle Object as documented here.
Let me know in case of any further questions.
Tobias
Edit: I might have misinterpreted the question. You don't necessarily need to know which view the dimensions belong to but rather the position of their GeometryIntents in relation to the Start and End Point of the Break Operation in addition to their orientation. That way you should be able to determine whether ShowBreakSymbol() should be true or not.
Does that approach make sense and is easy enough to implement?
Tobias Orlow
Designated Support Specialist
Customer Success Organization
Linkedin: www.linkedin.com/in/tobiasorlow/
Message 4 of 14
Maxim-CADman77
I believe this is related only to dimension style but not particular dimensionns.
Message 5 of 14
tobias.orlow
Ah I see what you mean.
Within the Dimension you can only query and change the property via the dimensions' "Style" and changes would be made to the style itself.
If you do have the requirement to set the BreakSymbol per Dimension, I believe it would be best to log it on the IdeaStation.
Tobias Orlow
Message 6 of 14
Maxim-CADman77
I'd rather prefer some (even tricky) workaround within next several days than ideal solution several years later.
Message 7 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Try below VBA code to identify broken dimension in drawing.
Sub Select_Broken_Dimension()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oDimension As DrawingDimension
    For Each oDimension In oSheet.DrawingDimensions
        Dim d As Double
        d = distance(oDimension.DimensionLine.StartPoint.Y, oDimension.DimensionLine.StartPoint.X, oDimension.DimensionLine.EndPoint.Y, oDimension.DimensionLine.EndPoint.X)
        d = d / 10
        If d <> oDimension.ModelValue Then
            Call oDoc.SelectSet.Select(oDimension)
    Next
End Sub
Function distance(ya As Double, xa As Double, yb As Double, xB As Double)
    distance = Sqr((ya - yb) ^ 2 + (xa - xB) ^ 2)
End Function
Please feel free to contact if there are any queries.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 8 of 14
Maxim-CADman77
This is good idea!
But still needs adding some analysis of the Drawing View.
I mean it doesn't take to consideration DrawingView Scale value (works as expected only for dimensions belong to 1:1 Scaled Views).
PS: I believe it's also worth to compare rounded values, like:
If Round(d,8) <> Round(oDD.ModelValue,8) Then
Message 9 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Please provide non confidential sample drawings (different scale) to test the feasibility.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 14
Maxim-CADman77
I believe you don't need another sample.
Just change Drawing View Scale value to something different  from "10:1".
Then to keep it working as expected you'll need to change accordingly the hard-coced multiplier in line
 d = d / 10
For Dimension that belongs to 5:1 Scaled View:
     d = d/5
For Dimension that belongs to 1:2 Scaled View:
    d = d*2
...etc.
Message 11 of 14
Maxim-CADman77
Message 12 of 14
Maxim-CADman77
I still hope it is possible to get scale multiplier of the parent view for each dimension...
Message 13 of 14
Maxim-CADman77
I'm attaching a sample set of model and drwing with several broken dimensions on several views with different scale.
I still hope somebody will help me to make VS (View Scale) variable an accosiative.
My current code is:
Sub Main
	Dim oIDW As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSh As Sheet = oIDW.ActiveSheet
	Dim oDD As DrawingDimension
	Dim MsgMody As String
	Dim VS As Double ' View Scale
	For Each oDD In oSh.DrawingDimensions
		MsgBody &= oDD.Text.Text
'		MsgBody &= oDD.ModelValue
		VS = 1/2 ' !!!!
		Dim d As Double = OnIDWdistMM(oDD.DimensionLine.StartPoint.Y, oDD.DimensionLine.StartPoint.X, oDD.DimensionLine.EndPoint.Y, oDD.DimensionLine.EndPoint.X) / VS
		MsgBody &= " (" &  Round(d,3) & ")" '
		If Round(d,8) <> Round(10*oDD.ModelValue,8) Then MsgBody &= " - BROKEN !!!"
		MsgBody &= vbCrLf
	Next
	MsgBox(MsgBody,,"Dimensions' Break status:")
End Sub
Function OnIDWdistMM(ya As Double, xa As Double, yb As Double, xB As Double)
	OnIDWdistMM = 10 * Sqrt((ya - yb) ^ 2 + (xa - xB) ^ 2)
End Function
Message 14 of 14
Maxim-CADman77
Just in case:
I've got the answer regarding View Scale here - https://forums.autodesk.com/t5/inventor-customization/determine-scale-of-the-drawingdimension-s-pare...
