I'd like to know the easiest (or at leas any) method to determine which DrawingView is parent for the given DrawingDimension.
To be more precise I need the ViewScale.
For the whole task context see https://forums.autodesk.com/t5/inventor-customization/determine-if-drawing-dimension-is-broken/td-p/...
Solved by JhoelForshav. Go to Solution.
Drawing dimensions doesn't belong to any view, but the sheet. Their intent(s) however has a view parent.
Try this ilogic code to get the scale of the drawingview a picked drawing dimension is attached to 🙂
Dim oDrawDim As GeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select dimension") Dim oView As DrawingView Select Case oDrawDim.Type Case ObjectTypeEnum.kLinearGeneralDimensionObject, ObjectTypeEnum.kAngularGeneralDimensionObject oView = oDrawDim.IntentOne.Geometry.Parent Case ObjectTypeEnum.kRadiusGeneralDimensionObject, ObjectTypeEnum.kDiameterGeneralDimensionObject oView = oDrawDim.Intent.Geometry.Parent End Select If oView Is Nothing MsgBox("Dimension type not supported") Exit Sub End If MsgBox("Scale factor (double) = " & oView.Scale) MsgBox("Scale string = " & oView.ScaleString)
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
Try below VBA code to select broken dimension depends on drawing view scale.
Sub Select_Broken_Dimension()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oDimension As DrawingDimension
For Each oDimension In oSheet.DrawingDimensions
Dim d As Double
d = distance(oDimension.DimensionLine.StartPoint.Y, oDimension.DimensionLine.StartPoint.X, oDimension.DimensionLine.EndPoint.Y, oDimension.DimensionLine.EndPoint.X)
Dim oScale As Double
If oDimension.Type = kLinearGeneralDimensionObject Then
Set oView = oDimension.IntentOne.Geometry.Parent
oScale = oView.Scale
d = d / oScale
If d <> oDimension.ModelValue Then
Call oDoc.SelectSet.Select(oDimension)
End If
End If
Next
End Sub
Function distance(ya As Double, xa As Double, yb As Double, xB As Double)
distance = Sqr((ya - yb) ^ 2 + (xa - xB) ^ 2)
End Function
Thanks and regards,
I've marked this as solution but in fact it fails with some message (I believe in English it sounds like "Object variable or With block variable not set ") if dimension is retrieved.
..so I still need some help.
Please provide non confidential drawing to reproduce the same error.
Thanks and regards,
Please find set of the sample files attached.
The retrieved dimensions wasnt easy because they have intenttype = kNoPointIntent
I found a way to get the view though. You could clean the code up a bit but I think this should work 🙂
Dim oView As DrawingView Dim oDrawDim As GeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select dimension") Dim oSheet As Sheet = ThisDoc.Document.ActiveSheet Select Case oDrawDim.Type Case ObjectTypeEnum.kLinearGeneralDimensionObject, ObjectTypeEnum.kAngularGeneralDimensionObject If oDrawDim.Retrieved Dim FoundObjects As ObjectsEnumerator = oSheet.FindUsingPoint(oDrawDim.IntentOne.PointOnSheet) If FoundObjects.Count = 0 Then FoundObjects = oSheet.FindUsingPoint(oDrawDim.IntentTwo.PointOnSheet) For Each oObj In FoundObjects If oObj.Type = ObjectTypeEnum.kDrawingCurveSegmentObject oView = oObj.Parent.Parent Exit For End If Next Else oView = oDrawDim.IntentOne.Geometry.Parent End If Case ObjectTypeEnum.kRadiusGeneralDimensionObject, ObjectTypeEnum.kDiameterGeneralDimensionObject If oDrawDim.Retrieved Dim FoundObjects As ObjectsEnumerator = oSheet.FindUsingPoint(oDrawDim.Intent.PointOnSheet) For Each oObj In FoundObjects If oObj.Type = ObjectTypeEnum.kDrawingCurveSegmentObject oView = oObj.Parent.Parent Exit For End If Next Else oView = oDrawDim.Intent.Geometry.Parent End If End Select If oView Is Nothing MsgBox("Dimension type not supported") Exit Sub End If MsgBox("Scale factor (double) = " & oView.Scale) MsgBox("Scale string = " & oView.ScaleString)
Jhoel Forshav
Please find set of sample files where failure occures on Diameter and Angular dimensions
Since the dimensions doesn't belong to a view it's almost impossible to cover all scenarios.
One of these dimensions were attached to a centermark that was attached to a view, the other was attached to a centerline that was attached to a centermark that was attached to a view. As you probably can tell by that, there are so many possible paths from the dimensions geometry intent to a view. It can require countless steps before a view is finally reached and every object type has its own property through which to access the object it's attached to...
Anyways... This rule covers the two new scenarios.
Dim oView As DrawingView Dim oDrawDim As GeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select dimension") Dim oSheet As Sheet = ThisDoc.Document.ActiveSheet Select Case oDrawDim.Type Case ObjectTypeEnum.kLinearGeneralDimensionObject, ObjectTypeEnum.kAngularGeneralDimensionObject If oDrawDim.Retrieved Dim FoundObjects As ObjectsEnumerator = oSheet.FindUsingPoint(oDrawDim.IntentOne.PointOnSheet) If FoundObjects.Count = 0 Then FoundObjects = oSheet.FindUsingPoint(oDrawDim.IntentTwo.PointOnSheet) For Each oObj In FoundObjects If oObj.Type = ObjectTypeEnum.kDrawingCurveSegmentObject oView = oObj.Parent.Parent Exit For End If Next Else Dim oIntent As GeometryIntent = oDrawDim.IntentOne If oIntent.Geometry.Parent.Type = ObjectTypeEnum.kSheetObject Then Select Case oIntent.Geometry.Type Case ObjectTypeEnum.kCentermarkObject oView = oIntent.Geometry.AttachedEntity.Geometry.Parent Case ObjectTypeEnum.kCenterlineObject oView = oIntent.Geometry.FitPoints(1).AttachedEntity.Geometry.Parent End Select Else oView = oIntent.Geometry.Parent End If End If Case ObjectTypeEnum.kRadiusGeneralDimensionObject, ObjectTypeEnum.kDiameterGeneralDimensionObject If oDrawDim.Retrieved Dim FoundObjects As ObjectsEnumerator = oSheet.FindUsingPoint(oDrawDim.Intent.PointOnSheet) For Each oObj In FoundObjects If oObj.Type = ObjectTypeEnum.kDrawingCurveSegmentObject oView = oObj.Parent.Parent Exit For End If Next Else Dim oIntent As GeometryIntent = oDrawDim.Intent If oIntent.Geometry.Parent.Type = ObjectTypeEnum.kSheetObject Then Select Case oIntent.Geometry.Type Case ObjectTypeEnum.kCentermarkObject oView = oIntent.Geometry.AttachedEntity.Geometry.Parent Case ObjectTypeEnum.kCenterlineObject oView = oIntent.Geometry.FitPoints(1).AttachedEntity.Geometry.Parent End Select Else oView = oIntent.Geometry.Parent End If End If End Select If oView Is Nothing MsgBox("Dimension type not supported") Exit Sub End If MsgBox("Scale factor (double) = " & oView.Scale) MsgBox("Scale string = " & oView.ScaleString)
Jhoel Forshav
I see. In fact attaching dimension to auxiliary geometry instead of model edge is a common practice.
Yet my task perobably can be simplified to solvable with couple assumptions/limitations ...
Let say:
1. I'm interested in analyzing only Linear dimensions (i believe there is no much sense in breaking other dimension types).
2. Healthy drawing should not contain any view overlaping or unattached dimensions
(parent view then can be determined indirectly as the one which range box "catches" both dimension attachement points, right?)
Even though it's common practice to attach demensions to auxiliary geometry, keep in mind that this geometry is not part of the drawingview object either. We have to work with how the API is built and what's exposed to us.
@Maxim-CADman77 wrote:I see. In fact attaching dimension to auxiliary geometry instead of model edge is a common practice.
Let say:1. I'm interested in analyzing only Linear dimensions (i believe there is no much sense in breaking other dimension types).
Something like this maybe?
Sub Main Dim oView As DrawingView Dim oDrawDim As GeneralDimension = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select dimension") Dim oSheet As Sheet = ThisDoc.Document.ActiveSheet If oDrawDim.Type <> ObjectTypeEnum.kLinearGeneralDimensionObject MsgBox("Not a linear dimension") Exit Sub End If Dim oIntPos1 As Point2d = oDrawDim.IntentOne.PointOnSheet Dim oIntPos2 As Point2d = oDrawDim.IntentTwo.PointOnSheet For Each dW As DrawingView In oSheet.DrawingViews If pointInView(oIntPos1, dW) Or pointInView(oIntPos2, dW) 'Change to "And" if you want to check if both is in view. oView = dW Exit For End If Next If oView Is Nothing MsgBox("Dimension type not supported") Exit Sub End If MsgBox("Scale factor (double) = " & oView.Scale) MsgBox("Scale string = " & oView.ScaleString) End Sub Function pointInView(ByRef pt As Point2d, ByRef oView As DrawingView) As Boolean If pt.X >= oView.Left AndAlso pt.X <= (oView.Left + oView.Width) If pt.Y <= oView.Top AndAlso pt.Y >= (oView.Top - oView.Height) Return True End If End If Return False End Function
I think it should be enough to check that at least one of the intent points is within the boundary of the view.
Jhoel Forshav
