assigning material with appearance to part from assembly
NachoShaw
Advisor Advisor
NachoShaw
Hey
from assembly level, i am trying to assign a material with its associated appearance. I am first clearing the part level appearance override as its been set in a file conversion.
Dim asmDoc As AssemblyDocument = FrmModelLoader._invApp.ActiveDocument
   Dim doc As Document
      For Each doc In asmDoc.AllReferencedDocuments
         If doc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            Dim Part As PartDocument = doc
            Dim p As PartComponentDefinition = Part.ComponentDefinition
            p.ClearAppearanceOverrides()
            asmDoc.Rebuild2()
     Next
    End Sub
While i doing this, i need to assign a material from a library (it should already be accessible from the part). I can assign the material but it doesnt assign the associated appearance. When i do it manually, it does.
Do i need to assign the appearance separately if assigning by code? If so, what is the best way to do that? All of the posts i found were either too old (predating Assets) or showing me how to get the materials into a text file...
Summary
From assembly level, i need to
loop assembly
for each part, clear appearance
assign a material
assign an appearance
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
I managed to resolve this
Nacho
