Getting Inventor application object from dll called from iLogic
Skadborg.NTI
Skadborg.NTI
How do I get access to the document object (or the Inventor application object) from a dll called from iLogic? Do I have to pass it from the iLogic rule to my dll?
In the dll I can get the Vault connection like this:
C#:
Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections.Connection vltConn;
vltConn = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.VaultConnection;
VB.NET:
Dim vltConn as Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections.Connection
- can I get the Inventor application object in some similar way?
chandra.shekar.g
Autodesk Support
Autodesk Support
@Skadborg.NTI,
Refer below link to get Inventor application in VB.net.
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/lesson-2-programming-overvie...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Skadborg.NTI
Thank you - I am familiar with the functionality to attach to a running Inventor process. Or to create one, and then attach to it.
But here I am talking about a dll being referenced by an iLogic-rule. I would need to get the same Inventor process that runs the rule - not just "a" Inventor process. So can code in the dll "see" the InventorApplication that the rule is running in?
