Checking if part is a sub component of subassembly
NachoShaw
Advisor Advisor
NachoShaw
Hey
Is there a way to check if a part is at top level or in a sub assembly? I need to process any part in the top level assembly that is not in a sub assembly, and only process those directly at top level, ignoring any part in a sub assembly. Im currently using
Dim oRefDocs As DocumentsEnumerator = CurrDoc.AllReferencedDocuments
   For Each oRefDoc As Inventor.Document In oRefDocs
   'do my things here
   Next
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
I managed to resolve this in a crude way by matching referencing documents
Nacho
leonque
Built in a top level Assembly containing the whole Project.
From there, export structurated BOM list to Excel format. make sure you include the category "File name"
Once in excel, at the Elemet colum you get a hyerarchy path delimted by "." for every single part or assembly.
Once splitted in different columns, This path allows you to identify direct parents at every level.
Double filter top level assemblies, By iam type an  direct parents=Void. then you get top leve assemblies
I hope that this give you a clue.
In ms POWERBI you have specific functions to manage Depth of paths automatically. In Excel is a little bit mor work, but you can get it at the end.
NachoShaw
Hi
Thanks for the reply. i would prefer not to have any external excel work. The current process that works for me is the following:
   Dim ParentName As String = _invApp.ActiveDocument.FullDocumentName
   Dim CheckParentName As String = oRefDoc.ReferencingDocuments(1).FullDocumentName
   If ParentName = CheckParentName Then
   'its a top level component
Next
Nacho
