IS NOT VAULTED & FILE IS READ ONLY
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
In my iLogic endeavors, I some times need to retrieve the following information releted to the current active document.
I appreciate some one replying me with a sample code. Thanks.
johnsonshiue
Hi! Let me move this message to Inventor Customization forum.
Many thanks!
Software Test Engineer
RoyWickrama_RWEI
Thanks for the good work.
I will take care next time!
WCrihfield
Not sure about the "Vaulted" part, because I'm not currently using Vault, but I think I can help you out with the ReadOnly status.  The following code can determine if the file is ReadOnly or not.
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oFI As New System.IO.FileInfo(oDoc.FullFileName)
If oFI.IsReadOnly = True Then
	MsgBox("This file is ReadOnly.", vbOKOnly, "READ-ONLY")
There is also the "IsModifiable" boolean you can check too.
If oDoc.IsModifiable = False Then
Wesley Crihfield
(Not an Autodesk Employee)
RoyWickrama_RWEI
Thanks a lot. Great help.
