Determinde the model parameter name
I used this code to make a new workplane which is offset from the XZ plane
by a distance of .2
How to determine what model parameter (name) of .2?
Thx,
On Error Resume Next
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oOriginWP As WorkPlane
Set oOriginWP = oDoc.ComponentDefinition.WorkPlanes.Item("YZ Plane")
Dim oNewWP As WorkPlane
Set oNewWP = oDoc.ComponentDefinition.WorkPlanes.Item("New WorkPlane")
If Err Then
Err.Clear
Else
Set oNewWP =
oDoc.ComponentDefinition.WorkPlanes.AddByPlaneAndOffset(oOriginWP, 0.2,
False)
oNewWP.Name = "New WorkPlane"
End If
www.CVAengineering.com
IV11 Pro. sp2 and IV2008 Pro. sp1
Vault 2008 sp1
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 91.85
SpacePilot V 3.3.6
oNewWP.Definition.Offset.Name
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
by a distance of .2
of  .2?
Thx,
    Dim
    Set oDoc =
    Dim oOriginWP As
WorkPlane
    Set oOriginWP =
    Set oNewWP =
WorkPlane")
    If Err
Then
Err.Clear
Else
        Set oNewWP =
False)
        oNewWP.Name = "New
WorkPlane"
    End If
href="http://www.CVAengineering.com">www.CVAengineering.com
IV11
Vault 2008 sp1
Window  XP Pro
sp2
NVIDIA FX 3400
91.85
SpacePilot  V 3.3.6
Thx, Brian
CVA
Vault 2008 sp1
Window  XP
Pro  sp2
NVIDIA FX 3400
91.85
SpacePilot  V 3.3.6
I
by a distance of .2
of  .2?
Thx,
    Dim
    Set oDoc =
    Dim oOriginWP As
WorkPlane
    Set oOriginWP =
Plane")
    Dim oNewWP As
WorkPlane
    Set oNewWP =
WorkPlane")
    If Err
Then
Err.Clear
Else
        Set oNewWP =
False)
        oNewWP.Name = "New
WorkPlane"
    End If
IV11
Vault 2008 sp1
Window  XP Pro
sp2
NVIDIA FX 3400
91.85
SpacePilot  V 3.3.6
Hi Brian,
Do you know how I would be able to find function calls like the one you used here? If this post wasn't here there would be no way to figure out that there are more properties under the .Definition object. Is there a better way to use the object browser in VS?
-Thomas
