Issue With iProp Constants
03:05 PM
I'm making a macro to crawl an assembly, enumerate through the parts and dump some select iProps to an Excel sheet. I seem to be having an odd mix-up on the iProp constants though. For example, I write this:
For Each Component In oAllComponents
Set oCustomPropSet = Component.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Set oDesignPropSet = Component.PropertySets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}")
oDesignPropSet.Item(kPartNumberDesignTrackingProperties).Value = "Part_Number"
...and it writes Part_Number into the Checked By field. Same thing happens when I try to retrieve the iProp. So I check the constant to see what number it is and the kPartNumberDesignTrackingProperties is equal to 5, which I think is right from the research I've already done so I haven't accidentally changed my constant value somehow.
So, what is going on? Am I missing something dumb?
