OnActivateCommand name for new part/assembly from inventor standard toolbar
dsmith
dsmith
Hi All
I need to find out the command that is run when you select new part/assembly etc from the Inventor Standard Toolbar.
It does not seem to case a oUserInputEvents_OnActivateCommand
I use oUserInputEvents_OnActivateCommand to capture a number of commands and oAppEvents_OnNewDocument to trap new document .
The only trouble with oAppEvents_OnNewDocument is that it is fired whenever a new document is created.
I need to trap just when a user selects either
File>New Done this
and
Inpace component creation Done This
and
Selects New>Assembly/Part etc from the Standard Toolbar dropdown.
I have an addin that issues filenames automatically using customisable numbering schwemas or interfaces with Productstream to reserve item numbers from the Item Master and us this as the filename.
Just one small problem is working with frame generator of Tube and Pipe that still invoke the standard oAppEvents_OnNewDocument event.
Hence I need to just trap selection of commands that create new parts assemblies etc.
Regards
Dave
dsmith
Anyone got any ideas regarding this Because I am STUCK!!!!!
Dave
dsmith
Seems I am on my own with this!!!
paulschuepbach
Hi Dave,
just a idea (I have not tried): check the CommandManager
--> ActiveCommand or so.
Hope this helps.
Best, Paul
dsmith
Tried that. No command posted
Sorry, it is not currently possible to trap the new document creation from
the standard toolbar dropdown. However, this is very high on our priorities
for the next release.
Sanjay-
wrote in message news:5787956@discussion.autodesk.com...
