Derived Part Loosing work features from parent Assembly ?
cencinaNB2ET
cencinaNB2ET
I derived an assembly into a simplified part with code.
I include work features.
I Suppress the link to the parent assembly.
Work features (Planes), appear in my derived part under a node  that has the assembly name.
Then I Unsuppress the link to the assembly to carry out an update.
And that node is gone with all the planes.
So my new planes in the derived part that are constrained to the assembly planes are now with nothing to attach to.
Hence Error...
This is something that just happened recently.
Is this known I read a post from 2017 that had a similar problem.
https://forums.autodesk.com/t5/inventor-forum/derived-part-dependent-on-workplane-not-updating-autom...
bradeneuropeArthur
are you deriving with a fix LOD or View Representation?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
