Sketch consumption by PartFeature (browser tree analysis)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'm composing iLogic rule that should inform user whether the IPT has any sketch that was not used for creating Solid/Surface Bodies (return Sketch Name if any).
Initially I thought I would use Sketch.Parent property value but now I don't think it was good idea because it only returns Part or SheetMetal Component definition enumerator.
Now I think the fastest way would be to analyse browser tree (check if there is any parent PartFeature object for each Sketch) but i lack experience of processing the model-tree. Till now I have this:
Dim oSketch As Sketch
Dim oCompDef As PartComponentDefinition
oCompdef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oControlDef As ControlDefinition
oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFindInBrowserCtxCmd")
For each oSketch in oCompDef.Sketches
	ThisApplication.ActiveDocument.SelectSet.Clear
	ThisApplication.ActiveDocument.SelectSet.Select(oSketch)
	oControlDef.Execute
	MsgBox(oSketch.Name) ' Comment after debugging
'if ??? Then  MsgBox (oSketch.Name): Exit For
Next
Could somebody hint what should I put instead "???" to achieve my goal  ?
Please vote for Inventor-Idea Text Search within Option Names
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Hoping that below iLogic code might help to determine sketch which is not used for solid body.
oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
For Each oSketch In oCompDef.Sketches
	If oSketch.Consumed = False Then
		MessageBox.Show("Name of sketch which is not used to create solid body : "+oSketch.Name, "Sketch name")
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
