I have been able to turn a multi-solid sheet metal part into a derived assembly but can't seem to track down an example that will work for (nested) Sketch blocks*.
The API documentation is sketchy on the subject at best so I figured it was time to ask here.
Many thanks in advance,
Alex.
*I know I can do this manually using the "Make Components" function but it will only work on solid/surface bodies or Sketch blocks, never seemingly at the same time.
I have hit a snag that looks like a bug in the Inventor 2017 API or perhaps my understanding of it?
If I run this iLogic code:
' Run this inside a Multi-Solid part
Sub MakeComponentsProgrammatically(ByVal ThisPart As PartDocument, ByVal ResultsFolder As String)
' Folder to place the new components:
' assembly and subcomponents
'Dim ResultsFolder As String = System.IO.Path.GetDirectoryName(ThisPart.FullFileName) & "\" & System.IO.Path.GetFileNameWithoutExtension(ThisPart.DisplayName) & "\"
Dim Thispartname As String = System.IO.Path.GetFileNameWithoutExtension(ThisPart.FullFileName)
ThisApplication.StatusBarText = ResultsFolder & " - " & Thispartname
If Not System.IO.Directory.Exists(ResultsFolder) Then
System.IO.Directory.CreateDirectory(ResultsFolder)
End If
' Create the assembly
Dim asm As AssemblyDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject)
Call asm.SaveAs(ResultsFolder + System.IO.Path.GetFileNameWithoutExtension(ThisPart.DisplayName) + ".iam", False)
Dim solidbody As SurfaceBody
For Each solidbody In ThisPart.ComponentDefinition.SurfaceBodies
If solidbody.Name.StartsWith("Solid") Then
Continue For
End If
' Create part for each body
Dim prt As PartDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
' Set iProperties >> Project >> Description
' It's inside "Design Tracking Properties"
Dim p As Inventor.Property = prt.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Description")
p.Expression = solidbody.Name
Dim dpcs As DerivedPartComponents = prt.ComponentDefinition.ReferenceComponents.DerivedPartComponents
Dim dpd As DerivedPartUniformScaleDef = dpcs.CreateUniformScaleDef(ThisPart.FullDocumentName)
' Exclude the other solid bodies
Dim dpe As DerivedPartEntity
For Each dpe In dpd.Solids
If Not dpe.ReferencedEntity Is solidbody Then
dpe.IncludeEntity = False
End If
Next
Call dpcs.Add(dpd)
'DOES NOT WORK!!
' Could have any name but we use the solid body's name
'if we can work out how to use the sketch blocks in this part they too need a material. which isn't one of these:
'If solidbody.name.contains("Panel") Then
' SetMaterialToPart(prt, "Glass")
'Else
' SetMaterialToPart(prt, "Aluminum 6061")
'End If
Dim newfilename As String = Regex.Replace(solidbody.Name, "([a-z](?=[A-Z])|[A-Z](?=[A-Z][a-z]))", "$1 ")
Call prt.SaveAs(ResultsFolder + Thispartname + "-" + newfilename + ".ipt", False)
' Place an instance of it inside the assembly
Dim mx As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
Call asm.ComponentDefinition.Occurrences.AddByComponentDefinition(prt.ComponentDefinition, mx)
' Don't need it anymore
Call prt.Close
Next
Call asm.Close
End Sub
It runs just fine - a little on the slow side but the multi-body part is 16MB and has up to 40 bodies contained within.
Yet if I run this version in a .NET addin I have written that otherwise functions perfectly normally I always get an error on the second time the "for next" loop calls surfacebody.name (highlighted in red below):
g_inventorApplication.StatusBarText = ResultsFolder & " - " & Thispartname
End If
Dim asm As AssemblyDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject)
For Each solidbody As SurfaceBody In ThisPart.ComponentDefinition.SurfaceBodies
Try
If solidbody.Name.StartsWith("Solid") Then ' errors here on the second loop through the collection in VB.NET
Continue For
End If
Catch ex As Exception
Continue For
End Try
Dim prt As PartDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
Dim DerivedPartComponentsColl As DerivedPartComponents = prt.ComponentDefinition.ReferenceComponents.DerivedPartComponents
Dim DerivedPartUniformScaleDefObj As DerivedPartUniformScaleDef = DerivedPartComponentsColl.CreateUniformScaleDef(ThisPart.FullDocumentName)
' Exclude everything
DerivedPartUniformScaleDefObj.ExcludeAll()
'and then only include the solidbody
For Each DerivedPartEntityObj As DerivedPartEntity In DerivedPartUniformScaleDefObj.Solids
If Not DerivedPartEntityObj.ReferencedEntity Is solidbody Then
DerivedPartEntityObj.IncludeEntity = False
Else
DerivedPartEntityObj.IncludeEntity = True
End If
Next
Call DerivedPartComponentsColl.Add(DerivedPartUniformScaleDefObj)
'DOES NOT WORK!!
'Else
'End If
Dim mx As Matrix = g_inventorApplication.TransientGeometry.CreateMatrix()
Call prt.Close()
Next
Call asm.Close()
End Sub
Can anyone shed any light on this?
EDIT: This is the code from Adam's original post, not anything to do with Sketch blocks, but since I linked to the original article I figured it would be silly to start a new thread.
Right, so I managed to test the ilogic rule I wrote in comparison to the .NET addin and I've found that whilst the ilogic rule is able to pull out the surfacebody.name value every time, the exact replica code inside of a .NET addin fails after the first iteration through the loop every time.
It's alsmost as if there's some kind of timeout that means that the .NET addin forgets it was looking at the surfacebodies collection for this specific part file.
Private Sub RunCreateBalconies(Context As NameValueMap)
Dim StartTime As DateTime
Dim ElapsedTime As TimeSpan
ToggleWorkfeaturesAndSketches(False)
'check for invisible bodies since Inventor will ignore them by default.
Dim invisiblebodies As Boolean = False
Do While invisiblebodies = False
For i As Integer = 1 To g_inventorApplication.ActiveDocument.ComponentDefinition.SurfaceBodies.Count
Dim surfacebody As SurfaceBody = g_inventorApplication.ActiveDocument.ComponentDefinition.SurfaceBodies.Item(i)
If surfacebody.Visible = False Then
invisiblebodies = True
Exit For
End If
Next
Loop
Dim result As DialogResult = Nothing
If invisiblebodies = True Then
result = MessageBox.Show("We found invisible bodies!" & vbCrLf & "Should we stop and check this is correct before continuing?", "Found Invisible Bodies", MessageBoxButtons.YesNo)
End If
If result = DialogResult.Yes Then
Exit Sub
End If
'check debug settings - provides ~10% speed boost if screen updating is disabled.
If My.Settings.BalconyCreationHiddenOnScreen Then
g_inventorApplication.ScreenUpdating = True
g_inventorApplication.UserInterfaceManager.UserInteractionDisabled = False
Else
g_inventorApplication.ScreenUpdating = False
g_inventorApplication.UserInterfaceManager.UserInteractionDisabled = True
End If
g_inventorApplication.SilentOperation = True
Dim ThisDoc As PartDocument = g_inventorApplication.ActiveDocument
Dim RootFolder As String = System.IO.Path.GetDirectoryName(ThisDoc.FullFileName) & "\"
UpdateStatusBar("Parameter update after each parameter change is set to: " & UpdateAfterEachParameterChange.ToString)
'Excel objects
Dim xlApp As Excel.Application
Dim wb As Workbook
Dim ws As Worksheet
Dim range As Range
Try
xlApp = GetOrCreateInstance("Excel.Application")
wb = xlApp.Workbooks.Open(RootFolder & System.IO.Path.GetFileNameWithoutExtension(ThisDoc.FullFileName) & ".xlsx")
'MessageBox.Show("Successfully opened: " & RootFolder & System.IO.Path.GetFileNameWithoutExtension(ThisDoc.FullFileName) & ".xlsx")
ws = wb.Worksheets(1)
range = ws.UsedRange
MessageBox.Show("Error info: " & vbNewLine & ex.ToString)
Exit Sub
End Try
StartTime = Now()
Try
Dim BalconyList As List(Of Balcony) = New List(Of Balcony)
Dim TmpBalconyList As List(Of Balcony) = New List(Of Balcony)
'need to start after the row headers
For ExcelRow As Integer = 2 To range.Rows.Count
Dim cellval As Excel.Range = range.Cells(ExcelRow, 1)
If cellval.Value2 = "Total" Then ' we reached the last row of the table!
Exit For
End If
'data collection
Dim partnumber As String = range.Cells(ExcelRow, 6).Value2 & "-" & range.Cells(ExcelRow, 2).Value2
Dim BayNumber As String = range.Cells(ExcelRow, 1).Value2 'Column A
Dim StackNumber As String = range.Cells(ExcelRow, 2).Value2 'Column B
Dim DimAFeatureFinCentres As Double = range.Cells(ExcelRow, 3).Value2 'Column C
Dim DimBOverallBalconyLength As Double = range.Cells(ExcelRow, 4).Value2 'Column D
Dim BalconyType As String = range.Cells(ExcelRow, 5).Value2 'Column E
Dim Bnumber As String = range.Cells(ExcelRow, 6).Value2 'Column F
Dim SolidLeft As Boolean = IIf(range.Cells(ExcelRow, 7).Value2 = "SolidLeft", True, False) 'Column G
Dim SolidRight As Boolean = IIf(range.Cells(ExcelRow, 8).Value2 = "SolidRight", True, False) 'Column H
Dim IsMirrored As Boolean = IIf(SolidRight, True, False)
Dim GlassBoth As Boolean = IIf(range.Cells(ExcelRow, 9).Value2 = "GlassBoth", True, False) 'Column I
Dim NumGlassPanels As Double = Convert.ToDouble(range.Cells(ExcelRow, 10).Value2) 'Column J
Dim tmpbalcony As Balcony
tmpbalcony = New Balcony(partnumber,
BayNumber,
StackNumber,
DimAFeatureFinCentres,
DimBOverallBalconyLength,
BalconyType,
Bnumber,
SolidLeft,
SolidRight,
IsMirrored,
GlassBoth,
NumGlassPanels)
TmpBalconyList.Add(tmpbalcony)
Next
'need to iterate through the tmpbalcony list and differentiate between solidleft,solidright and glassboth instances.
'because we know we (currently) have glassboth versions for everything we can safely disable it.
For Each tmpbalcony As Balcony In TmpBalconyList
If tmpbalcony.SolidLeft Then
Dim leftbalcony As New Balcony(tmpbalcony.PartNo,
tmpbalcony.BayNum,
tmpbalcony.stackno,
tmpbalcony.DimAFeatureFinCentre,
tmpbalcony.DimBOverallBalconyLength,
tmpbalcony.BalconyTypeNum,
tmpbalcony.BayNo,
tmpbalcony.SolidLeft,
tmpbalcony.SolidRight,
tmpbalcony.IsMirrored,
tmpbalcony.Glassboth,
tmpbalcony.NumPanels)
leftbalcony.IsMirrored = False
leftbalcony.PartNo = leftbalcony.PartNo & "-L"
leftbalcony.Glassboth = False
BalconyList.Add(leftbalcony)
ElseIf tmpbalcony.SolidRight Then
Dim rightbalcony As New Balcony(tmpbalcony.PartNo,
tmpbalcony.BayNum,
tmpbalcony.stackno,
tmpbalcony.BayNo,
rightbalcony.IsMirrored = True
rightbalcony.PartNo = rightbalcony.PartNo & "-R"
rightbalcony.Glassboth = False
BalconyList.Add(rightbalcony)
End If
'add glassboth variant to balconylist
Dim glassbothbalcony As New Balcony(tmpbalcony.PartNo,
tmpbalcony.BayNum,
tmpbalcony.stackno,
tmpbalcony.BayNo,
glassbothbalcony.SolidRight = False
glassbothbalcony.SolidLeft = False
glassbothbalcony.IsMirrored = False
glassbothbalcony.PartNo = glassbothbalcony.PartNo & "-B"
glassbothbalcony.Glassboth = True
BalconyList.Add(glassbothbalcony)
Next
UpdateStatusBar("List of Balconies to create = " & BalconyList.Count & " Long")
'uses the Excel data.
For Each balcony As Balcony In BalconyList
Dim GlassBothSides As Boolean = balcony.GlassBoth
Dim BalconyIsMirrored As Boolean = balcony.IsMirrored
'need to map relevant class objects to Inventor Parameters.
SetParameter(My.Settings.BalconyLengthParamName, balcony.DimBOverallBalconyLength)
Select Case balcony.BalconyTypeNum
Case My.Settings.BalconyT1Params(0) 'T1
SetParameter(My.Settings.BalconyNumArmsParamName, My.Settings.BalconyT1Params(1))
SetParameter(My.Settings.BalconyArmSpacingParamName, My.Settings.BalconyT1Params(2))
Case My.Settings.BalconyT2Params(0) 'T2
SetParameter(My.Settings.BalconyNumArmsParamName, My.Settings.BalconyT2Params(1))
SetParameter(My.Settings.BalconyArmSpacingParamName, My.Settings.BalconyT2Params(2))
Case My.Settings.BalconyT3Params(0) 'T3
SetParameter(My.Settings.BalconyNumArmsParamName, My.Settings.BalconyT3Params(1))
SetParameter(My.Settings.BalconyArmSpacingParamName, My.Settings.BalconyT3Params(2))
Case Else
'nothing
End Select
'Try
Dim ResultsFolder As String = RootFolder & System.IO.Path.GetFileNameWithoutExtension(balcony.PartNo) & "\"
Dim NewFileName As String = ResultsFolder & balcony.PartNo & ".ipt"
'need to update here otherwise we will not see any errors in the updated parameter values.
'InventorVb.DocumentUpdate()
UpdateStatusBar(NewFileName)
ThisDoc.SaveAs(NewFileName, False)
' Catch
'MessageBox.Show("If we're having trouble saving, the PartNo could be referencing a vaulted part " & vbCrLf & "Or you copied the spreadsheet and haven't fully updated every row!")
'Exit Sub
'End Try
Dim oErrorMgr As ErrorManager = g_inventorApplication.ErrorManager
Dim oMessageSection As MessageSection = oErrorMgr.StartMessageSection
'only continue if we have zero errors or warnings
If Not oMessageSection.HasErrors Or Not oMessageSection.HasWarnings Then
MakeComponentsProgrammatically(ThisDoc, ResultsFolder, BalconyIsMirrored, GlassBothSides)
End If
' End section by clearing all messages in section
oMessageSection.ClearMessages()
If My.Settings.BalconyCreationStepByStepDebugging Then
result = MessageBox.Show("Want to continue exporting files?", "Say Yes To continue, No to stop!", MessageBoxButtons.YesNoCancel)
If result = vbNo Then
MessageBox.Show("Processing stopped after completion of: " & System.IO.Path.GetFileNameWithoutExtension(ThisDoc.FullFileName))
Exit For
End If
End If
Next
'modify parameters to suit
'MessageBox.Show("Parameters Updated, Continuing")
'ThisDoc.Document.SaveAs(originalfilename, False)
'MessageBox.Show("Files Created, Finished")
BalconyList = Nothing
'if some error occurs then this code will be executed
g_inventorApplication.SilentOperation = False
Finally
wb.Close(False)
xlApp.Quit()
If Not xlApp Is Nothing Then
xlApp.ReleaseInstance()
'xlApp = Nothing
End If
End Try
ElapsedTime = Now().Subtract(StartTime)
MessageBox.Show("Operation took " & ElapsedTime.TotalMinutes & " Minutes")
End Sub
Private UpdateAfterEachParameterChange As Boolean = False
''' <summary>
''' This is re-copied from the iLogic rule in the hope that it fixes whatever went wrong.
''' Need to make sure that all workfeatures are visibility = false prior to running it.
''' CURRENTLY THIS DOES NOT TAKE INTO ACCOUNT THE NAMING DIFFERENCE REQUIRED FOR THE GLASSONBOTHSIDES OPTION!
''' </summary>
''' <param name="ThisPart"></param>
''' <param name="ResultsFolder"></param>
Sub MakeComponentsProgrammatically(ByVal ThisPart As PartDocument, ByVal ResultsFolder As String, ByVal IsMirrored As Boolean, ByVal GlassOnBothSides As Boolean)
End If
'Also check if the glassonbothsides option is true and react accordingly.
If GlassOnBothSides Then
'this should take care of the feature suppression/unsuppression where required:
SetParameter("GlassBoth", "1")
'Throw New NotImplementedException
'This method needs to include the ability to suppress/unsuppress key Part features OR Suppress/Unsupress components within the resultant assembly.
'it should also provide functionality to rename any parts and/or the parent Assembly for those part files to make them unique.
Else
SetParameter("GlassBoth", "0")
End If
Dim assemblydocument As AssemblyDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject)
Call assemblydocument.SaveAs(ResultsFolder + System.IO.Path.GetFileNameWithoutExtension(ThisPart.DisplayName) + ".iam", False)
'Dim solidbody As SurfaceBody
For i As Integer = 1 To ThisPart.ComponentDefinition.SurfaceBodies.Count
Dim surfacebody As SurfaceBody = ThisPart.ComponentDefinition.SurfaceBodies.Item(i)
Dim surfaceBodyName As String = surfacebody.Name
If surfaceBodyName.StartsWith("Solid") Then
Continue For
End If
Dim partdocument As PartDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
Dim p As Inventor.Property = partdocument.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Description")
p.Expression = surfaceBodyName
Dim derivedpartcomponents As DerivedPartComponents = partdocument.ComponentDefinition.ReferenceComponents.DerivedPartComponents
Dim derivedpartuniformscaledefinition As DerivedPartUniformScaleDef = derivedpartcomponents.CreateUniformScaleDef(ThisPart.FullDocumentName)
Dim derivedpartentity As DerivedPartEntity
For Each derivedpartentity In derivedpartuniformscaledefinition.Solids
If Not derivedpartentity.ReferencedEntity Is surfacebody Then
derivedpartentity.IncludeEntity = False
End If
Next
Call derivedpartcomponents.Add(derivedpartuniformscaledefinition)
'DOES Not WORK!! AF 2016-07-19
'If we Then can work out how To use the sketch blocks In this part they too need a material. which isn't one of these:
'If surfaceBodyName.Contains("Panel") Then
' SetMaterialToPart(partdocument, "Glass")
'Else
' SetMaterialToPart(partdocument, "Aluminum 6061")
'End If
Dim newfilename As String = Regex.Replace(surfaceBodyName, "([a-z](?=[A-Z])|[A-Z](?=[A-Z][a-z]))", "$1 ")
Call partdocument.SaveAs(ResultsFolder + Thispartname + "-" + newfilename + ".ipt", False)
'Check whether the part needs to be mirrored based on the IsMirrored variable
If IsMirrored Then
MirrorDerivedPart(partdocument, DerivedPartMirrorPlaneEnum.kDerivedPartMirrorPlaneYZ) 'default is currently YZ Plane
End If
Dim oOcc1 As ComponentOccurrence = assemblydocument.ComponentDefinition.Occurrences.AddByComponentDefinition(partdocument.ComponentDefinition, mx)
'should really figure out how to add additional occurrences of the relevant 'C' channels and fins where appropriate so we get a completed assembly.
'base work axes
Dim XAxis As WorkAxis
Dim YAxis As WorkAxis
Dim Zaxis As WorkAxis
With assemblydocument.ComponentDefinition
XAxis = .WorkAxes(1)
YAxis = .WorkAxes(2)
Zaxis = .WorkAxes(3)
End With
If surfaceBodyName = "C2" Then ' or whatever we called this!?
Dim objCol As ObjectCollection = g_inventorApplication.TransientObjects.CreateObjectCollection
'add the desired occurrence to be patterned
objCol.Add(oOcc1)
'to get this working we need to look into creating an object collection from this page:
' http://adndevblog.typepad.com/manufacturing/2012/12/inventor-create-pattern-of-component-occurrences.html
Call assemblydocument.ComponentDefinition.OccurrencePatterns.AddRectangularPattern(objCol,
YAxis,
True,
GetParameter(My.Settings.BalconyCSpacingParameterName).Expression,
My.Settings.BalconyChannelsCount)
ElseIf surfaceBodyName = "Fin" Then ' or whatever we called this!?
objCol.Add(oOcc1)
'uncomment when the one above works correctly!
YAxis,
True,
My.Settings.BalconyFinsCount)
ElseIf surfaceBodyName.Contains("Panel") Then ' then demote by panel name into sub-assemblies
ElseIf surfaceBodyName = "LongSpineRight" Then
ElseIf surfaceBodyName = "LongSpineLeft" Then
ElseIf surfaceBodyName = "ShortSpine" Then
ElseIf surfaceBodyName = "SpineConnectingPlateRight" Or surfaceBodyName = "SpineConnectingPlateLeft" Then 'create individual patterns of these components.
objCol.Add(oOcc1)
YAxis,
True,
GetParameter(My.Settings.BalconySpineFixingHoleParamName).Expression,
My.Settings.BalconyConnectingPlateCount)
End If
Call partdocument.Close()
Next
Call assemblydocument.Close()
End Sub
FWIW: I have not included a bunch of accompanying methods but the above shows how a user might iterate a multi-body part file, export the bodies using the API and also pattern the resultant bodies inside the newly created assembly file.
Which leads me back to my original question:
Is there any way to also include Sketch blocks in the above method? I know that when running the Make Components tool manually you can select either bodies or sketch blocks but not both at once; does the same restriction apply when using the API?
I haven't looked at this code in ages but as best I can remember it wasn't designed to work with Solid Rectangular patterns.
At the time I thought about doing that, but it made sense (to me at least) to derive the first solid into the assembly, and then use the Assembly pattern function instead. IIRC the two reasons for this were:
Because the derived solid components were identical and the code would have created a new derived component with a different name.
Because the derive process already took far too long as it was, and adding another step seemed like overkill when the built-in tools would suffice.
Ultimately, the customer I was building this for decided that their "dumb Excel-driven method" was better than my automated approach. Ho-hum.
Cheers,
Alex.
PS. I might resurrect this code to see if improvements in the underlying architecture in the releases since 2016 have improved the derive-component processing speed at all.
The code is great and quick and sometimes - no idea why - it is taking the patterned solids as well into derived, don't ask me why.
I do understand where you come from but issue starts if you need to modify a pattern - this can only be done on feature level. On assembly level it will take on all components - sure I can use extrude/cut to modify one by one but this will not give real length of a part ( I use Woodwork for Inventor BOM) when modified.
Think about if you have a framed wall and you want to dump in a window and cut the effected studs in this area as well get the correct length of each modified stud.
Did you have any idea if i can refer back to the pattern in the part and read solids create by this pattern and dump this into derived as well?
' Run this inside a Multi-Solid partSubMain()
' Folder to place the new components:' assembly and subcomponentsDimfAsString: f = "C:\temp\test1\"' Make sure the folder existsDimfsoAsObjectfso = ThisApplication.FileManager.FileSystemObjectIfNotfso.FolderExists(f) ThenCallfso.CreateFolder(f)
DimdocAsPartDocumentdoc = ThisApplication.ActiveDocument' doc = ThisDoc.Document' Create the assemblyDimasmAsAssemblyDocumentasm = ThisApplication.Documents.Add(kAssemblyDocumentObject)
DimsbAsSurfaceBodyForEachsbIndoc.ComponentDefinition.SurfaceBodies' Create part for each bodyDimprtAsPartDocumentIfNotsb.Name.Contains("@") Thenprt = ThisApplication.Documents.Add(kPartDocumentObject)
' Set iProperties >> Project >> Description' It's inside "Design Tracking Properties"TryiProperties.Value("Project", "Part Number") = sb.NameCatchEndTryDimdpcsAsDerivedPartComponentsdpcs = prt.ComponentDefinition.ReferenceComponents. _
DerivedPartComponentsDimdpdAsDerivedPartUniformScaleDefdpd = dpcs.CreateUniformScaleDef(doc.FullDocumentName)
' Exclude the other solid bodiesDimdpeAsDerivedPartEntityForEachdpeIndpd.SolidsIfNotdpe.ReferencedEntityIssbThendpe.IncludeEntity = FalseEndIfNextCalldpcs.Add(dpd)
' Could have any name but we use the solid body's nameCallprt.SaveAs(f + sb.Name + ".ipt", False)
' Place an instance of it inside the assemblyDimmxAsMatrixmx = ThisApplication.TransientGeometry.CreateMatrix()
IfNotsb.Name.Contains("@") ThenCallasm.ComponentDefinition.Occurrences. _
' Don't need it anymoreCallprt.CloseEndIfEndIfNextCallasm.SaveAs( _
f + Left(doc.DisplayName, Len(doc.DisplayName) - 4) + _
".iam", False)
Callasm.ActivateEndSub
As you can see I filter parts on sb.name and block the code to generate the part and to dump into the assembly - however, the derived is a big issue and is cross checking with sb - means it will not see the rectangular as of now.
I think I solved it and now as well rectangular pattern will get incorporated:
Of course you need to adjust for what you are looking - rectangular, circular, extrusion etc... and select your correct pattern number.
As well I came up with a solid body renaming rule which is using same logic and will rename all affected solids for each pattern feature by feature name. (see second code)
' Exclude the other solid bodiesDimdpeAsDerivedPartEntityDimoPCDAsPartComponentDefinition = doc.ComponentDefinitionDimoRectPatNameAsString = oPCD.Features.RectangularPatternFeatures(3).NameForEachdpeIndpd.SolidsForEachoSolidAsSurfaceBodyInoPCD.SurfaceBodiesForiAsInteger = 1 TooSolid.AffectedByFeatures.CountIfoSolid.AffectedByFeatures(i).Name = oRectPatNameThenIfNotdpe.ReferencedEntityIsoSolidThendpe.IncludeEntity = TrueIfNotdpe.ReferencedEntityIssbThendpe.IncludeEntity = FalseEndIfEndIfEndIfNextNextNextCalldpcs.Add(dpd)
".iam", False)
