How to create a closed 3D bspline using the API
jean-marc_langlois
jean-marc_langlois
Hi all,
I have some data I'm trying to write to Inventor using the API, and I have been unable so far to create a closed bspline programmatically...
Through the "TransientGeometry::CreateBSplineCurve" and the "Sketch3d::SketchFixedSplines3d::Add" methods, I create bsplines and get the expected result, but for closed curves, I am clueless at this point - I never was able to end up with a programmatrically created bspline instance whose "CLosed" property was true...
I'm assuming this can be done, as when importing the attached IGES file in Inventor, I end up with a "SketchSpline3d" instance whose "Closed"property is "True"...
Thanks for any help that can be provided
jean-marc_langlois
Some more info on this...
Through sime VBA code, I can access the SketchSpline instance I programmatically created, and its "Closed" property is 'false', but accessing its BSplineInfo, the returned 'IsClosed' parameter is 'true'..?
Is there an explanation for this, or is this an inconsistency ?
This is the code I'm running:
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
Dim sketch As sketch3d
Set sketch = oCompDef.Sketches3D(1)
Rem get the Spline3d instance
Dim spline3d As SketchSpline3D
Set spline3d = sketch.SketchSplines3D(1)
Dim order As Long
Dim numPoles As Long
Dim numKnots As Long
Dim isRational As Boolean
Dim isPeriodic As Boolean
Dim isClosed As Boolean
Dim isPlanar As Boolean
Dim planeVector(1 To 3) As Double
Dim curve As BSplineCurve
Set curve = spline3d.Geometry
Rem get the curve's bspline info
Call curve.GetBSplineInfo(order, numPoles, numKnots, isRational, isPeriodic, isClosed, isPlanar, planeVector)
Rem this assertion fails !
Debug.Assert isClosed = spline3d.Closed
Have you ever been able to solve your problem? I seem to be stuck even a step before you. I can create a BSplineCurve but adding it to the SketchFixedSplines3d gives me an exception. Also - trying to create a closed BSplineCurve gives me a falsearugmentsexception when creating the spline. sadly the documentation is nearly non-existend for the functions.
any help would be appreciated, thx
