Plot in Inventor
Plot in Inventor
Plot in Inventor
Hello:
I am trying to create a routine to plot in Inventor.
When it gets to oSheet.Activate (text in red below), I get a Run-time error 5:  Invalid procedure call or argument.
Any help would be appreciated.  I believe the logic is correct, pending any API changes from prior versions.  Can you recommend a good book on API programming?
Thanks.
Private Sub cmdPlot_Click()
' Define application
Dim oApp As Inventor.Application
Set oApp = ThisApplication
' Define document
Dim oCurrentDoc As DrawingDocument
Set oCurrentDoc = oApp.ActiveDocument
' Define sheets
Dim oSheets As Sheets
Set oSheets = oCurrentDoc.Sheets
Dim oSheet As Sheet
Set oSheet = oCurrentDoc.Sheets.Item(1)
' Define print manager
Dim oPM As DrawingPrintManager
Set oPM = oCurrentDoc.PrintManager
' Get sheet size
Dim xx As Integer
Dim xy As Integer
Select Case oSheet.Size
Case kADrawingSheetSize
xx = (6 * 2.54)
xy = (3.12 * 2.54)
Case kBDrawingSheetSize
xx = (12 * 2.54)
xy = (3.12 * 2.54)
Case kCDrawingSheetSize
xx = (17 * 2.54)
xy = (3.12 * 2.54)
Case kDDrawingSheetSize
xx = (29 * 2.54)
xy = (3.12 * 2.54)
Case kEDrawingSheetSize
xx = (37 * 2.54)
xy = (3.12 * 2.54)
End Select
For Each oSheet In oSheets
oSheet.Activate
' Create a new sketch on the active sheet
Dim oSketch As DrawingSketch
Set oSketch = oCurrentDoc.ActiveSheet.Sketches.Add
' Open sketch for edit so the texhbox can be created
oSketch.Edit
Dim oTG As TransientGeometry
Set oTG = oApp.TransientGeometry
Dim sText As String
sText = txtStampText.Text
Dim oTextBox As Inventor.TextBox
Set oTextBox = oSketch.tectboxes.AddFitted(oTG.CreatePoint2d(xx, xy), sText)
oSketch.ExitEdit
' Requires plot to activate text
oPM.PrintToFile ("c:\temp\tmpinventor.plot")
' Predefine printers
Dim PRN As String
PRN = "\\PS64\HP Color LaserJet M750dn"
Dim PLT As String
PLT = "\\PS64\HP T2500"
oPM.ScaleMode = kPrintFullScale
oPM.PrintRange = kPrintAllSheets
oPM.Printer = PRN
oPM.PaperSize = kPaperSizeLetter
oPM.Orientation = kLandscapeOrientation
oPM.Printer = PRN
oPM.PaperSize = kPaperSize11x17
oPM.Printer = PLT
oPM.PaperSize = kPaperSizeCSheet
oPM.Printer = PLT
oPM.PaperSize = kPaperSizeDSheet
oPM.Printer = PLT
oPM.PaperSize = kPaperSizeESheet
End Select
oPM.SubmitPrint
oSketch.Delete
Next
End Sub
Owner2229
Hi, you have already "oSheet" once declared with a value assigned, so you can try to declare a new one.
Don't forget to also change the variable in your following Select Case.
End Select
Dim xSheet As Sheet For Each xSheet In oSheets xSheet.Activate
Select Case xSheet.Size
There might be also something else in it, but for now you can give it a try.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Dont I need to establish oSheet as a variable to use it?  I do not see it declared twice.  This code ran great in VB6, struggling in VBA...
Owner2229
Hi, these are first some rows of your code:
' Define document
' Define sheets
Dim oSheet As Sheet ' Here is oSheet declared
Set oSheet = oCurrentDoc.Sheets.Item(1) ' Here is it given value
End Select For Each oSheet In oSheets ' Here it is used to go through every sheet in sheets oSheet.Activate
Just try it with the xSheet.
You can also try to put this line before oSheet.Activate, as there might be an invalid sheet in your drawing.
If oSheet Is Nothing Then Continue For
oSheet.Activate
Mike
I have no idea why the program works now. I haven't even looked at it for two weeks or changed anything, but when I loaded and ran it today everything ran fine.
Thenks for your response.
