Deleting centerlines on a drawing
DWhiteley
Advisor Advisor
DWhiteley
I've got this bit of code that is supposed to delete all centerlines on my drawing sheet.
j = oSheet.Centerlines.Count
For i = 1 To j
Try
oSheet.Centerlines.Item(i).Delete()
Catch ex As Exception
End Try
Next
Howver, I find that (inellegantly) I have to run it a few times in my code to actually remove all centerlines.
For some reason I get exceptions on some. It's not as though they have child/parent relationships - they are just workplanes displayed on the drawing.
The workplanes were created using this code:
j = oPartCompDef.WorkPlanes.Count
For i = 4 To j
oWP = oPartCompDef.WorkPlanes.Item(i)
Dim oWPpx As WorkPlaneProxy
Call oOcc.CreateGeometryProxy(oWP, oWPpx)
Call oDrawingDoc.Sheets(1).DrawingViews(1).SetVisibility(oWPpx, True)
Next
Does anyone have any ideas on why this is happening?
Thanks in adavance
Dave
envisage uk
MechMachineMan
See if this works any better for you
Sub Main()
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oCL As Centerline
For Each oSheet in oDoc.Sheets
	oSheet.Activate
	For Each oCL in oSheet.Centerlines
		'If oCL.Attached = False
			oCL.Delete
		'End if 'Centerline attached
	Next 'Centerline
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
DWhiteley
many thanks, i'll give it a try
