Delete Suppressed Features in Part Document using Macro
This may help someone who looks for macro to delete the Suppressed Features in Part Document.
Function Delete_Suppressed_Feature()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
    ' Iterate through all featuresand Delete the Suppressed Features.
    Dim oPartFeature As PartFeature
    For Each oPartFeature In oPartDoc.ComponentDefinition.Features
        If oPartFeature.Suppressed = True Then
            On Error Resume Next
            oPartFeature.Delete
    Next
    MsgBox "All Suppressed Parts Features are now Deleted."
End Function
Regards
Alex
MechMachineMan
Annnd answers to the inevitable questions of "Can you make it not delete sketches?" etc. can be found here:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-32BF44C7-7F65-4991-AE07-2E31E0AD8E63
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
