Creating PDF, Defered Updates drawing, Remove Line Weights option doesn't stick
Message 1 of 10
Hello all,
I am creating a PDF from an Inventor .dwg with an iLogic code frankensteined from various sources.
I have some options, one of them being:
oOptions.Value("Remove_Line_Weights") = 1
This works when the dwg has Defered Updates OFF, but when the Defered Updates are ON, the line weight option doesn't do anything.
This is important because when printed, they look very different!
I'm sure it's because I have very little clue as to what I am doing, beyond my extreme Copy Jockey skills. Any ideas?
My full code below:
'check if file type is a drawing file
If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then
MessageBox.Show("This file is not a drawing file.", "iLogic")
Else If ThisDoc.Document.DocumentType = kDrawingDocumentObject Then
'If there is a problem creating the PDF, it's probably because one is already open with the same name
On Error Goto handlePDFLock
'sets the Approved Date in iProperties to NOW
iProperties.Value("Status", "Eng. Approved Date" ) = Now
'sets the current time as a custom value
iProperties.Value("Custom", "Time Saved") = Now.ToString("HH:mm:ss")
'sets the current date and time for filename saving
Dim NowDateTime = Now.ToString("yyMMdd") & Now.ToString("HHmm")
'saves the current doc
ThisDoc.Save
'get path of current file
strPATH = ThisDoc.Path
'get file name
strFNAME = ThisDoc.FileName(False)
'set Project and Description
strProject = iProperties.Value("Custom", "Job")
'Save PDF with options
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim oDrawing as DrawingDocument
oDrawing = ThisDrawing.Document
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1  ' a 1 removes the line weights
oOptions.Value("Vector_Resolution") = 4800
	'If there Is an AutoCad Model Space included, then don't print it
	If oDrawing.Sheets.Item(1).Name = "Model (AutoCAD)" Then
		iBeginSheet = 2
	Else iBeginSheet = 1
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Custom_Begin_Sheet") = iBeginSheet
oOptions.Value("Custom_End_Sheet") = 999
'Set the destination file name
oDataMedium.FileName = strPATH & "\" & strFNAME & " " & strProject & " " & NowDateTime &".pdf"
'Publish document.
Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Open the PDF file that was just created.
ThisDoc.Launch(oDataMedium.FileName)
Exit Sub
handlePDFLock:
MessageBox.Show("PDF WAS NOT SAVED.   Please close any open PDFs.", "No PDF for you")
Replies (9)
Message 2 of 10
bradeneuropeArthur
For me it works correctly.
Drawing lineweights on deferupdate on:
Pdf without:
Pdf With:
What inventor version are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
I'm using 2017. What are you using?
Message 4 of 10
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
Ok, thanks for checking and confirming it works in 2018.
I am going to upgrade, but it won't be for another month - too busy to do now!
Anyone else confirm that it either doesn't work in 2017, or does work in 2018?
Message 6 of 10
bradeneuropeArthur
Maybe this is the issue:
Change your code a bit.
I think there is an error at your oOptions declarations:
On Error GoTo handlePDFLock
ThisDoc.Save
'get file name
'Set Project And Description
strProject = iProperties.Value("Custom", "job")
Dim oDrawing As DrawingDocument
	'If there Is an AutoCad Model Space included, Then don't print it
		iBeginSheet = 2
	Else
		iBeginSheet = 1
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange'.kPrintAllSheets
oOptions.Value("Custom_End_Sheet") = oDrawing.Sheets.Count
'Publish document.
Exit Sub
handlePDFLock:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
Thanks for pointing that out!
I still am having trouble, I wonder if it has anything to do with Acrobat?
Message 8 of 10
bradeneuropeArthur
Please upload a pdf!
I was wondering that also!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 10
I can't post the drawing that I want to (proprietary), so I will make a new one soon and post that.
Message 10 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Did you get a chance to prepare sample drawing file which is non proprietary?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
