Delete projected entity
tim11_manhhieu
Message 1 of 13
tim11_manhhieu
Hi experts,
I am writing a macro to use in assembly environment, to punch a threaded hole by picking edge of drill hole.
The problem is that after creating the threaded hole, there are projected entities left.
I want to delete the yellow sketch circle and yellow sketch point as shown in the image.
iLogic or VBA are both fine.
Option Explicit
Sub XXX()
Dim oAssemDoc As AssemblyDocument
Dim oAssemDef As AssemblyComponentDefinition
Dim oFace As Object
Dim oOcc As ComponentOccurrence
Dim oPartDoc As PartDocument
Dim oPartDef As PartComponentDefinition
Dim oSketch As PlanarSketch
Dim oEntity As Object
Dim oEntityProxy As Object
Dim oSketchProxy As Object
Dim oEntityOcc As ComponentOccurrence
Dim x As Double
Dim y As Double
Dim oHoleCenters As ObjectCollection
Dim oHoleTapInfo As HoleTapInfo
Dim oTransGeom As TransientGeometry
Dim h As HoleFeature
Set oAssemDoc = ThisApplication.ActiveDocument
Set oAssemDef = oAssemDoc.ComponentDefinition
Set oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select face on part for new sketch")
If oFace Is Nothing Then Exit Sub
Set oOcc = oFace.ContainingOccurrence
oOcc.Edit
Set oPartDoc = ThisApplication.ActiveEditDocument
Set oPartDef = oPartDoc.ComponentDefinition
Set oSketch = oPartDef.Sketches.Add(oFace.NativeObject)
oSketch.Edit
Set oEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select entity to project")
If oEntity Is Nothing Then Exit Sub
Set oEntityOcc = oEntity.ContainingOccurrence
Call oEntityOcc.CreateGeometryProxy(oEntity, oEntityProxy)
Call oOcc.CreateGeometryProxy(oSketch, oSketchProxy)
Call oSketchProxy.AddByProjectingEntity(oEntityProxy)
oSketch.Adaptive = False
Set oTransGeom = ThisApplication.TransientGeometry
x = oSketch.SketchCircles.item(1).CenterSketchPoint.Geometry.x
y = oSketch.SketchCircles.item(1).CenterSketchPoint.Geometry.y
Set oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection
Call oHoleCenters.Add(oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(x, y)))
Set oHoleTapInfo = oPartDef.Features.HoleFeatures.CreateTapInfo(True, "ISO Metric profile", "M6x1", "6H", True)
Set h = oPartDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oHoleCenters, oHoleTapInfo, kPositiveExtentDirection)
oSketch.ExitEdit
ThisApplication.CommandManager.ControlDefinitions.item("AppReturnTopCmd").Execute
oOcc.Adaptive = False
End Sub
Replies (12)
Message 2 of 13
bradeneuropeArthur
How to define and keep that definition for the hole feature than?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
WCrihfield
What about turning the visibility of that sketch off instead.  The sketch needs to be there, because the HoleFeature is dependent on it.
PlanarSketch.Visible = False ('oSketch.Visible = False' in your code example)
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 13
WCrihfield
Another idea would be to use a WorkPoint as the location of the HoleFeature, instead of a projected sketch.  If doing it that way, you could use the HoleFeatures.CreatePointPlacementDefinition method to create a PointHolePlacementDefinition (uses a WorkPoint to define hole location).  We would usually have used the HoleFeatures.CreateSketchPlacementDefinition to create a SketchHolePlacementDefinition when defining the locations of HoleFeatures by way of SketchPoints, but they continue to support the older way of using an ObjectCollection containing SketchPoints also.  I would likely be a good idea to use the newer methods in any important future automation solutions though.  Just some additional thoughts.
Wesley Crihfield
Message 5 of 13
patrick.schlambHPACQ
Alternatively, you can remove reference of the projected item and it will no longer be a projection. The following code will break the reference to the projection and then ground the entity so you aren't left with unconstrained sketches.
For Each sketchEnt As SketchEntity In oSketch.SketchEntities
	sketchEnt.Reference = False
	Try
		oSketch.GeometricConstraints.AddGround(sketchEnt)
	Catch : End Try
Next sketchEnt
Message 6 of 13
marcin_otręba
try:
Dim oProjEnt As SketchEntity = oSketchProxy.AddByProjectingEntity(oEntityProxy)
instead of
and then just delete it after creating hole centers:
oProjEnt.Delete()
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 7 of 13
tim11_manhhieu
Thank you for response.
They are not dependent on each other, after creating the hole, the hole will depend on the sketch point.
The projected entity can be deleted if we delete all their constraints.
Message 8 of 13
tim11_manhhieu
I'll look into HoleFeatures.CreatePointPlacementDefinition more.
Since I'm almost there, there's only one small issue left.
Message 9 of 13
tim11_manhhieu
I tried it and it worked, thank you.
Message 10 of 13
tim11_manhhieu
Thank you for response. It still error.
Message 11 of 13
tim11_manhhieu
VBA for who need.
Option Explicit
Sub zzz()
Dim oFace As Object
Dim x As Double
Dim y As Double
Dim oSketchEntity As SketchEntity
Set oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select plane for tap hole: ")
oOcc.Edit
oSketch.Edit
Set oEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceCylindricalFilter, "Select drill hole face: ")
Call oSketchProxy.AddByProjectingEntity(oEntity.Edges.item(1))
For Each oSketchEntity In oSketch.SketchEntities
    oSketchEntity.Reference = False
Next
oSketch.SketchCircles.item(1).Delete
oOcc.ExitEdit (kExitToTop)
End Sub
Message 12 of 13
WCrihfield
I didn't actually say that the hole feature would be dependent on the projected geometry, but rather to the sketch, and did not think it would be wise to delete the sketch.  But now I understand you were just talking about breaking the 'projected Link', then deleting just that projected circle, instead of the sketch.  I also apparently did not pay close enough attention to one line in your code.  Since you are creating a 'new' SketchPoint within the sketch at the same 'location' of the projected circle's center, instead of finding then using the projected center point of the circle itself, that eliminated any dependency on the projected geometry.  If you had used the existing projected SketchPoint object to specify the hole feature's location, then deleting the projected sketch geometry would have likely broken the hole feature.  Also note that the new SketchPoint that you created is not 'grounded' or constrained in any way yet, so you may want to add that, if it is important.
Glad to see that you got it working OK.
Wesley Crihfield
Message 13 of 13
tim11_manhhieu
I have noted that SketchPoint is not dimensionally constrained.
I will manually constrain and that is also my intention.
During the design process, the hole position often has to be changed, so constraining the hole position is something that cannot be ignored.
The operation of punching the threaded hole below often takes a lot of time, so I found a solution for it.
