Degrees of Freedom - Macro
Hello Team,
Greetings!
Can anybody help me with a macro / or the method on how to get into the Degrees of Freedom.
I would like take the count of Translation and Rotation counts
Thanks in Advance!
Alex
bradeneuropeArthur
Yes this is possible:
Public Sub ComponentsWithDegreesOfFreedom()
        Dim oActiveAssDoc As AssemblyDocument
        Set oActiveAssDoc = ThisApplication.ActiveDocument
        Dim oTranslationCount As Long
        Dim oTranslationVector As ObjectsEnumerator
        Dim oRotationCount As Long
        Dim oRotationVector As ObjectsEnumerator
        Dim oCenterPoint As Point
        Dim oComponentOccurence As ComponentOccurrence
        For Each oComponentOccurence In oActiveAssDoc.ComponentDefinition.Occurrences
            oComponentOccurence.GetDegreesOfFreedom oTranslationCount, oTranslationVector, oRotationCount, oRotationVector, oCenterPoint
            MsgBox oTranslationCount
            MsgBox oTranslationVector.Count
            MsgBox oRotationCount
            MsgBox oRotationVector.Count
            MsgBox oCenterPoint.x
            MsgBox oCenterPoint.Y
            MsgBox oCenterPoint.Z
'Optional ground components If oComponentOccurence.Grounded = False Then oComponentOccurence.Grounded = True End If Next End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thanks a lot. Now I understand the mistake what I was doing wrong..
I was adding the Bracket here all the time, as I am not aware. Smiley Mad
    oComponentOccurence.GetDegreesOfFreedom (oTranslationCount, oTranslationVector, oRotationCount, oRotationVector, oCenterPoint)
Where my code was always failing at this line. I couldn't understand the method while reading some API and documents related to it.
Basically I am not a programmer, new bee to this VB as well, I am managing a CAD team, and thought of doing some automation, so started in own interest.
But it was quite fun doing Automation with Inventor. Smiley LOL
Thanks a lot for saving my time
Regards
Alex
Curtis_Waguespack
just adding an ilogic version of this that lists the DOF for under constrained components, in case it helps someone else in the future:
Dim MyArrayList As New ArrayList
    oComponentOccurence.GetDegreesOfFreedom _
	If oTranslationCount > 0 Or oRotationCount > 0 Then
		MyArrayList.add(oComponentOccurence.Name _
		& " :   (" & oTranslationCount + oRotationCount & ") degrees of freedom remaining")
	End If
Next
InputListBox("Displaying components with one or more degrees of freedom", _
MyArrayList, "", "ilogic", "Free moving components")
basile.sciaudeau
Good afternoon everyone,
I'm very interested about this topic but I don't want to count the number of Degree Of Freedom.
My goal is to know which axes or which rotation are degree of freedom.
Is someone can help me ?
Thank you in advance.
