Deactivate Object Not Working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Deactivation these after deactivate does not work
oTab = Nothing
When I start the Addin again the tab is still there after deactivate.
What is wrong in the code.
Public Sub SetupUserInterface(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean, ClientID As String)
oTab = oRibbon.RibbonTabs.Add(sName & "", "AknoorsMasterAddIn" & "", ClientID)
End Sub
Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
' This method is called by Inventor when the AddIn is unloaded.
' The AddIn will be unloaded either manually by the user or
' when the Inventor session is terminated.
' TODO: Add ApplicationAddInServer.Deactivate implementation
m_inventorApplication = Nothing
oTab = Nothing
System.GC.WaitForPendingFinalizers()
System.GC.Collect()
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
