customise export from idw to dwg
CherylR001
CherylR001
I am trying to customise the .xml file for exporting from an idw file to dwg and delete a layer when I do so. i thought i had an idea on how to do it but it's not working. Any chance someone can have a look at the file I've edited and tell me where I'm going wrong.
Cheryl
bradeneuropeArthur
What are you trying to do?
  1. You have an existing .idw file
  2. You try to export it to a .dwg file
    • inventor dwg
    • Autocad dwg
  3. what layer are you trying to suppress
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
CherylR001
1. Yes, I have an existing idw file
2. I want to export to an AutoCad dwg file
3. I want to suppress a layer called IssueNumber. It is a layer with sketch symbols on that I don't necessarily want on the AutoCad dwg file that is being sent to the laser cutting firm
Cheryl
bradeneuropeArthur
Think that this is to be done in the INI file:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Or With This:
<?xml version="1.0" encoding="utf-16" standalone="yes"?>
This file contains the instructions for editing a DWG/DXF
file.
The format of these instructions as follows.   Within a
given pair of <editLayer> tags, the <name> tag specifies
the name of the layer to edit while the <setName> tag
specifies the new name for the layer.
Within a given pair of <addLayer> tags, the <name> tag
specifies the name of the layer to add.
Within a given pair of <deleteLayer> tags, the <name> tag
specifies the name of the layer to delete.
New <addLayer>, <deleteLayer>, <editLayer> tags can be added
in this exact sequence as needed by mimicking the structure
below.  The tags are processed in the same sequence:
Layer 0 cannot be deleted.  Using <deleteLayer> on layer 0
only deletes the entities on the layer.
                     BEGIN DTD SECTION
Do not modify the DTD section of this file.  It is used to
verify that the content of the file is valid.
<!DOCTYPE dwgEdits [
	<!ELEMENT dwgEdits		(layers)>
	<!ELEMENT layers		(addLayer*, deleteLayer*, editLayer*)>
	<!ELEMENT editLayer		(criteria, actions)>
	<!ELEMENT addLayer		(criteria)>
	<!ELEMENT deleteLayer		(criteria)>
	<!ELEMENT criteria		(name)>
	<!ELEMENT actions		(setName)>
	<!ELEMENT name			(#PCDATA)>
	<!ELEMENT setName		(#PCDATA)>
	<!ATTLIST dwgEdits version CDATA #REQUIRED>
                      END DTD SECTION
<dwgEdits version='1.0'>
	<layers>
		<addLayer>
			<criteria>
				<name>MyExtraLayer</name>
			</criteria>
		</addLayer>
		<deleteLayer>
			<criteria>
				<name>IssueNumber</name>
			</criteria>
		</deleteLayer>
		<editLayer>
			<criteria>
				<name>IV_TANGENT</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Tangent Lines</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_BEND</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Bend Lines</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_BEND_DOWN</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Bend Lines backside</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_TOOL_CENTER</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Tool Centers</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_TOOL_CENTER_DOWN</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Tool Centers backside</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_ARC_CENTERS</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Arc Centers</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_OUTER_PROFILE</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Outer Profile</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_FEATURE_PROFILES</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Feature Profile</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_FEATURE_PROFILES_DOWN</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Feature Profile backside</setName>
			</actions>
		</editLayer>
		<editLayer>
			<criteria>
				<name>IV_INTERIOR_PROFILES</name>
			</criteria>
			<actions>
				<setName>FlatPattern_Interior Profile</setName>
			</actions>
		</editLayer>
	</layers>
</dwgEdits>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
