Or With This:
<?xml version="1.0" encoding="utf-16" standalone="yes"?>
This file contains the instructions for editing a DWG/DXF
file.
The format of these instructions as follows. Within a
given pair of <editLayer> tags, the <name> tag specifies
the name of the layer to edit while the <setName> tag
specifies the new name for the layer.
Within a given pair of <addLayer> tags, the <name> tag
specifies the name of the layer to add.
Within a given pair of <deleteLayer> tags, the <name> tag
specifies the name of the layer to delete.
New <addLayer>, <deleteLayer>, <editLayer> tags can be added
in this exact sequence as needed by mimicking the structure
below. The tags are processed in the same sequence:
Layer 0 cannot be deleted. Using <deleteLayer> on layer 0
only deletes the entities on the layer.
BEGIN DTD SECTION
Do not modify the DTD section of this file. It is used to
verify that the content of the file is valid.
<!DOCTYPE dwgEdits [
<!ELEMENT dwgEdits (layers)>
<!ELEMENT layers (addLayer*, deleteLayer*, editLayer*)>
<!ELEMENT editLayer (criteria, actions)>
<!ELEMENT addLayer (criteria)>
<!ELEMENT deleteLayer (criteria)>
<!ELEMENT criteria (name)>
<!ELEMENT actions (setName)>
<!ELEMENT name (#PCDATA)>
<!ELEMENT setName (#PCDATA)>
<!ATTLIST dwgEdits version CDATA #REQUIRED>
END DTD SECTION
<dwgEdits version='1.0'>
<layers>
<addLayer>
<criteria>
<name>MyExtraLayer</name>
</criteria>
</addLayer>
<deleteLayer>
<criteria>
<name>IssueNumber</name>
</criteria>
</deleteLayer>
<editLayer>
<criteria>
<name>IV_TANGENT</name>
</criteria>
<actions>
<setName>FlatPattern_Tangent Lines</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_BEND</name>
</criteria>
<actions>
<setName>FlatPattern_Bend Lines</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_BEND_DOWN</name>
</criteria>
<actions>
<setName>FlatPattern_Bend Lines backside</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_TOOL_CENTER</name>
</criteria>
<actions>
<setName>FlatPattern_Tool Centers</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_TOOL_CENTER_DOWN</name>
</criteria>
<actions>
<setName>FlatPattern_Tool Centers backside</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_ARC_CENTERS</name>
</criteria>
<actions>
<setName>FlatPattern_Arc Centers</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_OUTER_PROFILE</name>
</criteria>
<actions>
<setName>FlatPattern_Outer Profile</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_FEATURE_PROFILES</name>
</criteria>
<actions>
<setName>FlatPattern_Feature Profile</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_FEATURE_PROFILES_DOWN</name>
</criteria>
<actions>
<setName>FlatPattern_Feature Profile backside</setName>
</actions>
</editLayer>
<editLayer>
<criteria>
<name>IV_INTERIOR_PROFILES</name>
</criteria>
<actions>
<setName>FlatPattern_Interior Profile</setName>
</actions>
</editLayer>
</layers>
</dwgEdits>
