- Mute
- Permalink
- Report
I started a thread in the other forum but I think I may need assistance with this using iLogic.
I have a content center sheet metal part that is placed into an assembly. I set the base length and width upon placing, then add flanges and such after placing. I have an iLogic rule to run before saving which populates the extents_length and extents_width parameters on a part level. These parameters are exported after creation into custom iProperties.
I can get an individual part to display the updated part number which is the product identifier along with the 2 custom iProperties (flat pattern) on a drawing parts lists. I manually manipulated this in the iProperties Part Number section by inputting = <Cost Center> - LENGTH <EXTENTS_LENGTH> - WIDTH <EXTENTS_WIDTH>
(I manually filled the part identifier in the Cost Center field as it was an empty slot)
I want this to happen on an assembly level because I want to group all the same parts that have the same part numbers (flat pattern) using the BOM Part Number Merge Setting.
When trying to implement this Part Number call out, it is pulling the "full sheet flat pattern" of sheet metal extents that is found in the original file used to publish the iPart to Content Center.
In the assembly the parts that I create, the true extents properties exist but the parts list is using the Family Table to implement the part number, which refers to the extents prior to creating in the assembly.
Would there be a rule that could "pull" the extents values from the sheet metal components so that I could implement the Part Number that I am trying to achieve.
My end goal if not clear, so when creating a Parts List of the assembly, I want to group together all the components that use the same stock sheet metal product, but split them up based on their flat pattern. Currently the all my sheet metal parts are grouped into one item with a random qty number.
I want to be able to reproduce what I did on a part level inside an assembly without having to manually do it for each part.
Any Autodesk Pro's out there that can help?
Thanks!
Sean
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
