Adding Partslist to all Sheets Based on Title Block of Sheet
jamesrHA2LQ
jamesrHA2LQ
I'm trying add a parts list to every sheet only if the sheet is using a specific Title Block.  I think my variable needs to be a String, so that I test the names of the Title Block.  I can assign a string variable to ActiveSheet.TitleBlock but then the variable doesn't iterate and stays constant.  If make the variable an object, and assign it oSheet.TitleBlock, then I'm not sure how to use the "if" statement to test for the correct title block.  Assigning an string to oSheet.TitleBlock just gives me the "Unable to cast COM object to class type String" error.
Any help would be awesome,
thanks.
'Places Parts List at top right corner for all drawing sheets with Anton B Title Block
Sub Main()
	Dim oDrawDoc As DrawingDocument = ThisDoc.Document
	Dim oSheet As Sheet = oDrawDoc.ActiveSheet
	Dim oDrawingView As DrawingView = oSheet.DrawingViews(1)
	Dim oBorder As Border = oSheet.Border
	Dim oPlacementPoint As Point2d
	Dim sTitleBlock As String
	For Each oSheet In oDrawDoc.Sheets
	oSheet.Update
	oDrawDoc.Update
		sTitleBlock = oSheet.TitleBlock
		If sTitleBlock = "Anton B"
			oPlacementPoint = oBorder.RangeBox.MaxPoint
			Dim oPartsList As PartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
	Next
End Sub
JelteDeJong
try it like this:
For Each oSheet As Sheet In oDrawDoc.Sheets
	Dim sTitleBlock As String = oSheet.TitleBlock.Name
	If (sTitleBlock.Equals("Anton B", StringComparison.InvariantCultureIgnoreCase)) Then
		Dim oDrawingView As DrawingView = oSheet.DrawingViews.Item(1)
		Dim oPlacementPoint As Point2d = oBorder.RangeBox.MaxPoint
Next
Jelte de Jong
Blog: hjalte.nl - github.com
jamesrHA2LQ
Thanks!  I actually ended up making the variable an object and using:
If oTitleBlock.Name = "Anton B"
 And that worked great.
Thanks again.
