Print only if custom iProperty is....
joshdollahan
joshdollahan
I want to modify my Batch Print code, so that will only print if it has custom iproperty.....of say 4
iProperties.Value("Custom", "ACS OP#") = 4
here is my code
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models'this expects that the model has a drawing of the same path and name
For Each oRefDoc In oRefDocs
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
'check to see that the model has a drawing of the same path and name
If(System.IO.File.Exists(idwPathName)) Then
                        Dim oDrawDoc As DrawingDocument
                oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
                oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3)
                Else
'If the model has no drawing of the same path and name - do nothing
Next
WCrihfield
Hi @joshdollahan.  Something like this maybe?
	Exit Sub
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
oAsmName = System.IO.Path.GetFileNameWithoutExtension(oAsmDoc.FullFileName)
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
	idwPathName = System.IO.Path.ChangeExtension(oRefDoc.FullFileName, ".idw")
	If Not System.IO.File.Exists(idwPathName) Then Continue For
	Dim oDrawDoc As DrawingDocument = ThisApplication.Documents.Open(idwPathName, True)
	Dim oPMgr As DrawingPrintManager = oDrawDoc.PrintManager
	'oPMgr.AllColorsAsBlack = False
	'oPMgr.NumberOfCopies = 1
	'oPMgr.Printer = "MyPrinter"
	'oPMgr.RemoveLineWeights = False
	oPMgr.PrintRange = PrintRangeEnum.kPrintAllSheets
	oPMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
	oPMgr.SubmitPrint
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Oops...forgot to add the check in there for the custom iProperty, which was the whole point of this post.
Here try this version instead.
	Exit Sub
	Dim oDCProps As PropertySet = oDrawDoc.PropertySets.Item("Inventor User Defined Propeties")
	If oDCProps.Count = 0 Then Continue For
	Dim oCPropFound As Boolean = False
	For Each oCProp As Inventor.Property In oDCProps
		If oCProp.Name = "ACS OP#" AndAlso oCProp.Value = 4 Then
			oCPropFound = True
	Next
	If oCPropFound = False Then Continue For
	oPMgr.SubmitPrint
Next
Wesley Crihfield
joshdollahan
I see where you are going, its the right start
It opens the first drawing and then errors.
Invalid class string (Exception from HRESULT: 0x800401F3 (CO_E_CLASSSTRING))
System.Runtime.InteropServices.COMException (0x800401F3): Invalid class string (Exception from HRESULT: 0x800401F3 (CO_E_CLASSSTRING))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.PropertySets.get_Item(Object Index)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
WCrihfield
I see it.  I was typing too fast and left out the second "r" in "Properties" in the name of the custom PropertySet.
Dim oDCProps As PropertySet = oDrawDoc.PropertySets.Item("Inventor User Defined Properties")
Wesley Crihfield
joshdollahan
Yes that fixed it. Changed a few things for my purposes and will add to it later. I appreciate your help. This one closes each of the drawings that don't fit the criteria
    Exit Sub
        If oCProp.Name = "'your property here" AndAlso oCProp.Value = 'your value here Then
            oCPropFound = True
    Next
    If oCPropFound = True Then Continue For
    oDrawDoc.Close
Next
