Custom iprop to be blank
GKPByDesign
GKPByDesign
I need help, my code won't allow my custom prop to have a blank answer. can someone help. When Cut = None, DIM to equal "" (BLANK)
If Cut = "Model A" Or Cut = "Model B" Or Cut = "Model C" Or Cut = "Model D" Or Cut = "Model E" Or Cut = "Model F" Then
	DIM = G_L1
End If
If Cut = "Model A - Small Side" Or Cut = "Model B - Small Side" Then
	DIM = G_L2
End If
If Cut = "None" Then
	DIM = ""
End If
chandra.shekar.g
Autodesk Support
Autodesk Support
@GKPByDesign ,
Hoping that below iLogic code may be helpful.
iProperties.Value("Custom", "DIM") = ""
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GKPByDesign
I need the code to be to if the cut equals none then custom I’m iprop is blank, like what I have written, but it keeps giving me an error ‘double’ with the code I have written
Sergio.D.Suárez
Hi, I ask you a question, the DIM parameter is numeric?
the parameters G_L1 and G_L2 are numeric?
if all are numeric you can not place in the value "" which is a text value of string, you must place the value zero. That's why the error message appears. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
GKPByDesign
Is there a way to make it blank at all?
