Bill of Material/Cut List to show multiple quantities with only 1 Assembly
I have a drawing of a basic cabinet, I have it set within an IDW with all the views and Ilogic etc. What I need is when we do multiples of this 1 cabinet how do i get the BOM to change the quantity of the parts to reflect this change. Adding the assembly multiple times seems ridiculous. Sending out 6 drawings of the same thing is silly. There has to be a way for me to add a Parameter "Count" and Have it multiply against the BOM qty. I cant seem to find a way that these link without using some weird column in I-prop.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that below forum discussion links may be helpful.
https://forums.autodesk.com/t5/inventor-customization/vba-edit-bom/td-p/7686934
https://forums.autodesk.com/t5/inventor-customization/write-bom-number-and-quantity-to-parts/td-p/7626722
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Sergio.D.Suárez
Hi, if you have a partslist on an active drawing sheet, you could use the following code to multiply the base quantity.
The code overwrites the original base quantity, multiplying it by a user defined multiple.
First you must write the name of your quantity column as it appears in your partslist (I have detailed it in red)
oColumn = "Quantity"   '''Enter the name of the quantity column of your partslist
multiple = InputBox("Indicate the multiple of the original quantity", "Multiple Quantities", "1")
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
oPartsList = oSheet.PartsLists.Item(1)
For i = 1 To oPartsList.PartsListRows.Count
	oPartsList.PartsListRows.Item(i).Item(oColumn).Static = False
Next
If IsNumeric(multiple) Then
		oQty = oPartsList.PartsListRows.Item(i).Item(oColumn).Value
		oPartsList.PartsListRows.Item(i).Item(oColumn).Value = oQty * multiple
	Next
 I hope the rule can be useful. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
